587,215 active members*
3,996 visitors online*
IndustryArena Forum > CAM Software > Vectric > Frist cut and strange movments
    Feb 2010
    I used the demo version of Cut2d. Im doing the wing spar. the first movment send my Z axis to the roof! i dont have limit switches yet so if its trying to home or somthing thats not good. When i look at the 3d screen it looks like the first move realy is high! All i want it to do is start at zero go down .125 and then finish the pocket and go up just enouph to move on and go down. Am i missing somthing. here is my file. Could it be somthing with safe Z?
    Attached Files Attached Files
    Jan 2009
    114
    I took a look at your code, "N50G00G43Z2.0000H4" is sending your Z to 2" which shouldn't be a problem. I did an air cut of your file and verified it as good. If the 2" doesn't sit well with you then edit the code to 0.50" or 0.25".
    What post proccessor are you using? Check that you're not using metric verses inch or visa versa. Also check Absolute verses Incremental.
    BTW, I guess those blokes don't know the difference between a Rib and a Spar....
    Fatboy
    Also consider that it's applying a length offset for Tool #4 with the G43 H4
    I remove the G43 from my Vectric post so that doesn't happen, as I don't use the length offset.
    Feb 2010
    Thank you! i found out what was wrong I was all messed up. It was in inchand mach was in MM. Also had the tool length wrong. lol it was a combo of evrything. I also had mach set up funny so that it would produce strange circles that were not in the code. I fixed it and managed to cut a few parts last night. its working great now. I just need to remember to zero the machine each time. I now know what tool crash meens. Thanks for the help.
  1. need heilp in my frist home made cnc
    By gndy_2030 in forum DIY CNC Router Table Machines
    Last Post: 03-17-2010, 10:18 PM
  2. 32i doing something strange
    By zman300 in forum Fanuc
    Last Post: 01-29-2010, 02:09 PM
  3. cutting aluminum for the frist time with cnc
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 07-22-2009, 01:22 AM
  4. frist time cnc router
    By luther in forum DIY CNC Router Table Machines
    Last Post: 08-06-2007, 05:07 AM
  5. frist cnc
    By fred klusmann in forum Mechanical Calculations/Engineering Design
    Last Post: 12-16-2005, 05:28 PM
