586,096 active members*
2,962 visitors online*
Results 1 to 6 of 6
    Apr 2005
    131
    Question SmartCam 11 post for Mach 3
    Hi all, would anyone have a post processor / code generator for mach 3?
    OR, which similar controller post could be used instead of a mach 3 specific to start building one? Say, modify a Fanuc or a Masak post?
    Paraman, Parabeast, Paramachine, Parameter.
    The many in one and the one in the many.
    Jan 2007
    1389
    you can download free generic code files on smartcamcnc.com
    smartcams code generators are the easiest code generators to play with. very simple.
    you will need the code generation book that should be avail on the site as well.
    Delw
    Feb 2008
    10
    Do you have a programming manual with code examples???
    Jan 2007
    1389
    I have the org manuals from dos too version 9 .
    They should be on smartcamcnc website
    Feb 2008
    10
    Hi, Are you referring to the SmartCam Manuals or the Mach3.
    I meant if you have a programming manual for the mach 3 I may be able to get a code generator going.
    I have been using Smartcam for quite a while and am now using freeform V17.6.
    I am not sure if you can send attachments through the forum here but if you can send it over and I'll take a look.
    Ed
    Jan 2007
    1389
    Was referring to the smartcam manuals
  1. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
  2. need post files for smartcam ( Haas machine )
    By cv252525 in forum Uncategorised CAM Discussion
    Last Post: 02-25-2008, 04:14 PM
