587,758 active members*
2,905 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > stepper motor driver speed problem , PLZ read one time
Results 1 to 1 of 1
    Jan 2011
    59
    Unhappy stepper motor driver speed problem , PLZ read one time
    guyz i am from india, i stuck at a point . i assembled a l297 and l298 driver, the driver is working nice but the problem is = the stepper motor is not running more then 150 rpm. if i try to run the motor more then 150rpm it just vibrates.
    i dont know what is wrong.
    my motor is 20KC/CM (or 280oz in)6 wire unipolar (i am using it as 4 wire bipolar) 1.5 amp per phase.
    I am using 2 X 12V 20AH = 24v20ah battery as a power supply.
    i am running that motor at 24V 2amp.
    i am attaching the driver file and images...
    plz plz help...
    (i seen on google videos that other guyz are getting 1500-3000 rpm from the same driver )
    Attached Files Attached Files
  1. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  2. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  4. Replies: 4
    Last Post: 08-07-2009, 06:23 AM
  5. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
