588,535 active members*
6,569 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MM MCX part into INCH based fixture
    May 2006
    804
    Is there an easy way to pull MM based part file
    into a Inch based fixture file?
    or just Xform scale 1 millimeter = 0.039 370 078 74 inch
    after the merge?
    I want to machine in inches.
    Been doing this too long
    Dec 2008
    3142
    Opening the MM part file, should also load the MM config file, all units are set to MM, etc. etc,
    Just load the INCH config file, it will ask to convert the graphics image to INCH, say YES
    and your done...
    Alt[F8] is shortcut to the system config dialog. bottom of dialog
    May 2006
    804
    Thanks, that was TOO easy, or is there such a thing as T00 easy? Yes I've been doing things the "old way" too long. However we built the Space Shuttle with punched cards, went to the moon with punched cards, finally ditched those in early 80's while on the B1-B job. Thanks
  1. Part is metric, drawing is inch
    By thebowman in forum Solidworks
    Last Post: 01-14-2010, 07:39 AM
  2. Cylindrical part milling fixture
    By umniy2000 in forum MetalWork Discussion
    Last Post: 08-30-2009, 03:48 AM
  3. How to fixture a part?? ...see post #10 for print
    By SSN Vet in forum MetalWork Discussion
    Last Post: 03-13-2009, 10:03 PM
  4. Making a fixture cavity from 3d part
    By Shepard in forum Mastercam
    Last Post: 04-10-2008, 03:18 AM
  5. Fixture for holding 31/32 Round Part
    By Smackre in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2007, 02:24 PM
