586,058 active members*
3,568 visitors online*
Results 1 to 16 of 16
    Aug 2010
    Pass Through?
    Any advice would be appreciated. My morntech 3050d has pass through doors, but in order to pass anything through the bed has to be lowered a bit and hence putting the beam out of focus. Am I overlooking something? Here is a tiny pic from the web.
    [IMG] [/IMG]
    Nov 2004
    69
    Can you post a pic of your laser lens assembly.
    Jan 2011
    Quote Originally Posted by lrob View Post
    this is the Morn MT-L960
    Aug 2010
    Here it is...[IMG]
    Jan 2011
    Hows that MornTech working for you? i have the large MT-L960 80w with all the options in transit to me as we speak and got it at a super price!
    Nov 2004
    69
    This looks very similiar to my laser. Mine has a set screw for removing the lens assembly. By loosening the set screw you should be able to raise and lower the lens and be able get the correct focus you need.
    Larry
    Aug 2010
    It's my first machine, and it has treated me right. I've read some horror stories about imported lasers, but this machine was ready to go on day one. I sometimes wish I had a larger bed, but 12 x 20 suits my needs most of the time. I would also kill for an an adobe illustrator plug in.
    Aug 2010
    Thanks Larry. Which screw would you say, there is one which is barely visible behind the air hose, and a couple others.
    Aug 2010
    That worked, thanks Larry. These machines don't always have the best support literature.
    Oct 2007
    1024
    laser
    you do not have a pass through access, all opening have to be closed before the laser will operate.There is talk of making a laser case with a small openning front and back no micro switches allowing a large object to pass through but has to be only 3/4 to 1 in thick
    Also you should get or make a focus templateout of plexiglass then you loosen the fitting on the head and manually focus
    Jul 2008
    776
    Typical chinese mistake - have pass thru doors but forgot make them enough to move material in focus.
    Oct 2007
    1024
    pass through
    with mine i think i could focus on 1/2 to 3/4 ,material if i had pass through(or cut it out my self)
    Aug 2010
    Hey all,
    Just to clarify the pass through works, doors open and all.
    Jul 2008
    776
    From your first post "in order to pass anything through the bed has to be lowered a bit and hence putting the beam out of focus"
    In GCC lasers for example, with opened door table have enough space for moving up and down to accept practically any thickness of material and set it in focus.
    Jan 2011
    Quote Originally Posted by Litografa View Post
    Basically what Lito is saying is that if you had spent another 26k you would'nt have had to adjust anything on your 50w laser......... although what he fails to mention is not every hobbyist can afford a high priced GCC laser.
    What he also fails to mention is anyone with a understanding how these machines operate can upgrade a china machine for still less then what a GCC sells for and still have enough to buy a new car.
    Spending 10k on a 12w GCC laser is pretty dayum goofy and spending 31k on a GCC 60w is even goofier for a hobbyist or even for a small business owner.
    Jul 2008
    776
    :cheers: of course you are right
    GCC is for making money
    China is for hobby
    peace!
  1. Step over 2nd/3rd pass
    By Sjotime in forum DIY CNC Router Table Machines
    Last Post: 12-09-2010, 07:30 AM
  2. Bad pass
    By ozstockman in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-04-2010, 08:32 AM
  3. Each pass different than the previous
    By gage1049 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2008, 09:47 AM
  4. cut depth per pass
    By christ371 in forum Dolphin CAD/CAM
    Last Post: 07-20-2008, 03:14 AM
  5. Can I run axes at different ipm on the same pass?
    By yorttroy in forum DIY CNC Router Table Machines
    Last Post: 01-04-2006, 07:34 PM
