586,907 active members*
3,049 visitors online*
Thread: Twin Turret
Results 1 to 6 of 6
    Jan 2011
    Twin Turret
    We have a twin turret Okuma LR15. Our current program is using both turrets. What I would like to is, at the end of the program loop back to the beginning and have it start automatically. I have tried "GOTO N10" at the end, but I am getting an alarm 423-2. I believe the twin turret is causing this alarm. Thank you.
    Feb 2009
    6028
    You would need to loop back on both turret programs, with a matching Pcode.
    Aug 2008
    62
    You need to reset the P code counter. See example.
    G13
    NSTRA G50 S2000 P-1
    CUTTING PROGRAM
    M100
    GOTO NSTRTA
    G14
    NSTRB G50 S2000 P-1
    CUTTING PROGRAM
    M100
    GOTO NSTRB
    NEND M30 OR M2
    Nov 2010
    different way to loop the program for twin turret with p-codes - do a simple machining program to execute one workpiece only. then make a schedule program. eg.
    abc.sdf
    pselect abc.min,,,Q500
    end
    machining program - abc.min - is a normal program
    schedule program - abc.sdf - is selecting your program abc and executes it for 500 times. you can try max 9999 repetitions. good enough for a bar work.
    Mar 2009
    1982
    nice example. whent the part, starting with line #6:
    G14
    NSTRB G50 S2000 P-1
    CUTTING PROGRAM
    M100
    GOTO NSTRB
    will be executed?
    Will the program cycle from GOTO NSTRTA to NSTRTA with no exit from cycle?
    Aug 2008
    62
    Quote Originally Posted by Algirdas View Post
    G14
    NSTRB G50 S2000 P-1
    CUTTING PROGRAM
    M100
    GOTO NSTRB
    will be executed?
    This is just a simple warm-up program. The M100's will hold the turret (lets say A-Turret), until the other turret (B-Turret) reaches the corresponding M100. Both turrets will then proceed to the GOTO statement at the same time
    and loop the program to the beginning.
    We just use Block Delete in this case to stop looping the program.
    G13
    (WARM UP)
    (TURN BLOCK DELETE OFF TO RUN)
    (TURN BLOCK DELETE ON TO STOP)
    NSTRA G50 S1000 P-1
    G0G94G97X20.Z20.S750T0303M42M3P10
    G1X8.5Z6.1F40.0
    Z3.8P11
    X8.0
    Z6.1
    M100
    G0X20.Z20.P20
    M1P25
    G13
    N20G0G94G97X20.Z20.S750T0505M42M3P30
    G1X8.5Z6.1F40.0
    Z3.8P31
    X8.0
    Z6.1
    M100
    G0X20.Z20.P40
    M1P45
    M100
    / GOTO NSTRA
    G14
    NSTRB G50 S1000 P-1
    G0G94G97X20.Z20.S750T0201M42M3P10
    G1X6.0Z3.8F40.0
    Z5.5P11
    X6.5
    M100
    G0X20.Z20.P20
    M1P25
    G14
    N40G0G94G97X20.Z20.S750T0707M42M3P30
    G1X6.0Z3.8F40.0
    Z6.5P31
    X6.5
    M100
    G0X20.Z20.P40
    M1P45
    M100
    / GOTO NSTRB
    NEND M30
  1. Replies: 10
    Last Post: 05-04-2023, 11:04 AM
  2. Okuma LC40 Twin Turret
    By brisbanite in forum Okuma
    Last Post: 12-14-2010, 11:18 PM
  3. okuma twin turret axis flip?
    By fishy steve in forum Okuma
    Last Post: 11-11-2010, 02:35 PM
  4. Looping twin turret programs
    By anyfish in forum Okuma
    Last Post: 05-07-2010, 03:32 PM
  5. DOOSAN Z290SM TWIN TURRET LATHE
    By CHAD LAWSON in forum Daewoo/Doosan
    Last Post: 01-22-2009, 03:25 PM
