586,688 active members*
2,147 visitors online*
Results 1 to 7 of 7
    Feb 2011
    Camtech Routermaster 25 problems
    I have an old (circa 1999 I think) Camtech routermaster 25 with what I believe is a CMC2 controller. The machine and "black box" seem to be fine but the PC the runs the software is dying. This machine has definitely gone well past it's life expectancy and I'd like to replace it with a new one.
    The software we use on this machine is called "TPCwin". I called up camtech (now axyz or some such thing) to see about getting another license for TPCwin. The lady I was speaking with claimed that any new computer must run windows 98 and have an ISA bus as the machine is "locked" to hardware in the computer. This is fine, but here is where it gets confusing.
    The computer currently running TCPwin has two ISA slots which are empty. The "black box" is connected directly to the serial port on the motherboard via a serial cable of some sort. I don't know the pinout of this cable but I recall that a standard straight through or null-modem cable did not work. I copied another program called "camplot" from the old dying PC to a relatively new laptop. Using camplot and a usb serial port I was able to download the OS, delete job files, etc. If I tried sending a g-code fill I get an error asking for a license key. There is also no parallel port dongle on the old PC.
    What is going on here? Since the old computer has no special ISA hardware, and a new computer can serially communicate to the controller how could it be "locked" to windows 98? Am I missing something? What should I do to upgrade to a newer computer? I'm hoping someone out there has experience with these machines and can help me out.
    Mar 2012
    I know this is an old thread and they have probably found an answer by now, but for anyone else searching this, here what I found.
    Camtech was a good company,but when AXYZ bought them, they are awful. They are the most unhelpful bunch of people I have ever dealt with. We had a problem similar to the one above and was told they could no longer support the old controller we had, but could upgrade our hardware for about $16,000!
    Then I found wincnc.net. They are the ones who did the contoller for camtech originally. For less than $2000 they sold me a new computer with a controller card and software. This interfaced with the stepper controller under my camtech table. They also walked me through setting it up and get me running better than when It was new. Unlike AXYZ, they are Very friendly and helpful. Also if you change over to the new system and would like your old TPCWin software to work with WinXP or Win7, contact me and I will be glad to send you a file to make it work. The old TPCWin software would install on a newer system, but would stop working after some time and give an invalid machine code message. AXYZ then wanted $100 "administrative fee" to generate a new serial number. I did this 4 times before I got it to work without needing their number. The crooks charged me every time.
    jarrodl1 at h**mail.com
    We are talking two different controllers here, CMC2 and CMC3 (Wincnc)
    Quote Originally Posted by jarrodl View Post
    DrProton has a CMC2 and is right, the ISA slots are empty because the CMC2 uses the com port to communicate to the machine. The CMC2 is a dedicated controller in the machine (older technology) and needs to be booted via the com port (the operating system is downloaded to the machine). You are also right in that the serial cable is NOT a standard cable pinout!
    When copying CAMPLOT folder remember to also copy the c:\windows\camplot.ini file as well as that is where your license lives. Put all files back into the same location as they were in the old computer!
    CAMPLOT is a 16-bit program, but can be run on Windows 7 and Keyspan make a good USB-to-serial adapter to use for the download cable.
    You are right jarrodl, Kelly Davis and the rest at Wincnc are indeed professionals and exellent to deal with!
    Hope that helps.
    Hans
    Eureka-cnc.com
    Nov 2012
    probably a little late but camplot universal key is 0000000000001
    thats thirteen 0 's followed by a 1
    Jan 2011
    5
    Hi Jarrod with regards to the Camtech machine can you help me with my problem because my camplot is asking me a new serial number. Your help will be greatly appreciated.
    Earl
    Jan 2011
    5
    hi I've tried the camplot universal key it doesn't work maybe you have other option or solution that might help me thank you.
    Earl
    Nov 2015
    Re: Camtech Routermaster 25 problems
    I know this thread is old, but I was reading this thread and I saw something interesting. I have a 1999 Camtech with the black box. I have been using this machine since new. I have been through 4 or 5 computers in that time frame. I have always just loaded windows XP back on them. I see that Hans mentioned that Camplot can be used on windows 7. How can this be done? I tried loading Camplot on a windows 7 machine and I couldn't get it to load. Any tips would help?
    I am running a 1999 routermaster Z7 52 x 102
    I design in Profilelab7.1 (signs)
    I output from Camplot.
  1. Camtech Routermaster II parts
    By rambaldi92 in forum Want To Buy...Need help!
    Last Post: 08-09-2017, 08:54 AM
  2. Replies: 1
    Last Post: 03-08-2013, 12:49 AM
  3. Routermaster 52
    By osi in forum CNC Machine Related Electronics
    Last Post: 02-05-2012, 10:35 PM
  4. Camtech routermaster 52 for sale
    By osi in forum Australia, New Zealand Club House
    Last Post: 03-18-2010, 10:09 PM
