603,416 active members*
2,001 visitors online*
Thread: Accuracy
    Mar 2010
    Accuracy
    I am machining these parts and sent a few off for approval. One of my concerns is what is not shown in this picture is 4 mounting holes on the sides where 2 are centered around the bearing. When I cut this part and turn on its side for drilling/tapping, how can I zero the machine around the middle bearing hole?
    For this particular part I don't think it will be an issue. But if I wanted to hold my closest tolerance there how could I do it?
    Jan 2007
    1332
    I would mount the part in a vise bearing hole face up. Set a mill stop at one end. Using a center finding tool find the center of the bearing hole then zero machine coordinates. http://i72.photobucket.com/albums/i1...nterFinder.jpg Remove part and place in vise on end with the same end against the work stop. I like Kurt groove lock work stops but overhang over the vise may mean an external work stop. Machine mounting holes.
    Don
    Mar 2010
    Thanks Don! I was trying to over complicate it, I can just set the zero before even taking it off the machine.
    Mar 2010
    72
    Method?
    Quote Originally Posted by Magnum164 View Post
    Did you bore the holes using a boring head or Circular interp. If the latter dow was the accuracy and roundness? Nice job.
    Mar 2010
    Quote Originally Posted by dirtridn2010 View Post
    Oops.. Sorry that was a rendering I did of the part and sent to the customer. It helps to get the job if they can visually see what the part will look like. If I can get a pic of the actual part I will.
    The bearing holes were cut using hole pocketing in SprutCam. I have to go back and see what the hole was actually cut at, but these last holes should have been a interference fit but the bearing was a little loose. But they were made before I resolved the zeoring issue on my machine so I am hoping the next batch will be correct. But the parts are still within tolerance, just not what I wanted.
  1. Design accuracy to mechanical accuracy
    By kbayram in forum Linear and Rotary Motion
    Last Post: 08-18-2010, 09:34 AM
  2. Getting Accuracy in X2
    By webgeek in forum Benchtop Machines
    Last Post: 01-30-2010, 07:45 PM
  3. Accuracy
    By zoltan in forum SheetCam
    Last Post: 12-14-2005, 04:14 PM
  4. What accuracy do I need?
    By energyforce in forum Waterjet General Topics
    Last Post: 12-02-2005, 07:51 PM
  5. Accuracy determination & accuracy improvement
    By rweatherly in forum DIY CNC Router Table Machines
    Last Post: 08-11-2005, 02:37 PM
