586,076 active members*
4,023 visitors online*
    Jan 2011
    Wiring Diagram Maho C700 Retrofit
    I´m looking for a wiring diagram for a Maho C700.
    Made 1978.
    I want to change the old defect control with a newer one (EMC2).
    1.) How can I control the servo card?
    Analog +-10V between W1 and GND?
    Is that correct?
    2.) Path measuring System:
    PE2470 is used.
    What kind of signal did I get from the probe?
    Digital Pulse or Sin/Cos?
    Are there any dokument available?
    Pins or any Manuals
    Thanks for your help
    andi
    Feb 2008
    9
    Smile GAONKAR
    SIEMENS 802D WITH ADI4 INTERFACE IS GOOD FOR THIS MACHINE
    WE HAD DONE MANY MACHINE WITH THIS CONTROL
    FAGOR 8035 IS ALSO GOOD CONTROL FOR THIS MACHINE.
  1. Maho MH400E retrofit to Mach3
    By jimmyBondi in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-09-2014, 08:53 PM
  2. Maho 400P Wirring diagram
    By F45CNC in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-05-2010, 08:01 PM
  3. help with wiring diagram for C6 CNC
    By JDsto in forum Syil Products
    Last Post: 01-10-2008, 01:37 AM
  4. Wiring Diagram
    By SCHMEOW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2007, 05:40 AM
  5. Bridgeport Retrofit Wiring Diagram
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 09-18-2006, 10:39 AM
