603,943 active members*
3,735 visitors online*
    Jun 2009
    5
    Smile BUILDING A PLASMA CUTTING MACHINE
    I want to build a CNC plasma cutting machine for my workshop.
    I work on CRCA and MS sheets with thickness 1.6mm to 12 mm.
    i need technical guidance and plans for building a one.
    can any one help me with my project...
    Jan 2008
    2247
    Good places to start:
    http://www.precisionplasmallc.com
    www.candcnc.com
    These guys supply components, parts, electronics and software for do it yourself builders. You have only provided cutting thickness specs....which are covered by the plasma cutter itself. You will need to determine the size of the machine, how you will hold the metal, how you will control fumes, how to control torch to work distance, etc, etc.
    Jim
    Jan 2011
    110
    Another vote for Precision Plasma LLC, and C & CNC!
    Jun 2009
    5
    i'm from india and importing from usa would be costly for me.
    i'm thinking of building it from scratch with components avl in india.
    i thank u for advising me about the need to find a method for holding the job.
    holding the flame and height control. and over all size of machine.
    i will decide on the above points and post my machine size and work holding soon.
    thank u jimcolt and bbchevy396 for ur advice.
  1. cnc router/CO2 laser machine/cnc plasma cutting machine
    By cncengraver in forum Chinese Machines
    Last Post: 06-26-2010, 03:48 AM
  2. Plasma cutting machine help
    By rommel~ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2009, 12:56 PM
  3. Needs Help... building CNC foam Cutting Machine
    By javagreen in forum CNC Wire Foam Cutter Machines
    Last Post: 09-27-2008, 06:39 PM
  4. Needs Help... building CNC foam Cutting Machine
    By javagreen in forum Stepper Motors / Drives
    Last Post: 09-19-2008, 02:45 PM
  5. CNC Plasma Cutting Machine Info
    By Heftifab in forum Waterjet General Topics
    Last Post: 08-19-2008, 09:31 PM
