588,342 active members*
5,192 visitors online*
Results 1 to 15 of 15
    Oct 2010
    Laser masking? what do you do?
    I tried using brown masking tape today, and I loved the results. The image came out so much cleaner. BUT removing the masking from the VERY detailed image was very tedious. I have seen the liquid mask on laserbit's site but it seems SO expensive. Are there alternatives to it? What do you use?
    Jul 2008
    776
    Paper transfer tape from any supplier of vinyl films. Cheaper is better )
    Oct 2010
    Ya know, I was thinking of that, but I just got back into doing signs after a 7 year break, and I'm SHOCKED at the price of transfer tape. R tape I used to buy was $10-15 for 12"x100yd rolls. Now they want $40+!!! It's friggin tape!
    Jul 2008
    776
    Inflation, expensive oil, financial crisis :drowning:
    Oct 2010
    The oil companies are driving up the price of masking tape... It's a conspiracy I tell you.
    Oct 2010
    Do you know a good mail order supplier to get cheap (quality and price) masking?
    Feb 2005
    469
    That wide blue medium tack painters tape works well for me.
    If you are talking about pictures on wood, you can put a good finish on the wood before engraving and the smoke stains will wipe right off with a rag or sponge dampened with Orange Clean or Windex or something similar.
    Oct 2010
    It's a mix of vector and raster work, I have found that a low power vector cut of the aztec calender looks FAR better than a raster of it. I haven't tried putting a finish on the wood first... I'll have to try that.
    Jul 2008
    776
    Cheapest but still good quality choice for wide (more than 2" - 5 cm) tape here in Europe is Oratape from ORAFOL. They have branch in USA also.
    Agree with SkipW - if engraving is not big, we also use painter tapes.
    Oct 2010
    I like the painters tape, unless the image is too big for one piece, I noticed if you overlap 2 pieces, the overlap etches at a different depth and it's very noticeable.
    Feb 2005
    469
    I've noticed that too. I have to carefully butt the edges together to avoid an overlap. Does painters tape come in wider sizes?
    Oct 2010
    Not really, that's why we were discussing sign masking, it comes in almost any size, and the plus side is it has lower tack than painters tape. I'm kind of currious if I tape down a piece of paper to the work, moisten the paper then cut through it if it will help or not... Has anyone tried this?
    Oct 2010
    I just got my shipment of Endura Perfect tear from Sign Warehouse. I tried it out on a painted piece of Luann and this is how it turned out. AWESOME!!!! It kept the paint nice and clean, It was easy to cleanup because of it's low tack, and it didn't gum up on the edges like higher tack masking tapes. Torque Bros Sign
    Mar 2016
    Re: Laser masking? what do you do?
    3m Pre Space Tape
    Feb 2016
    6
    Yes the lower tack is definitely an advantage, I have roll myself but have yet to try it on the engraver.
  1. Masking
    By zimba43 in forum Signmaking Topics
    Last Post: 02-05-2014, 05:36 PM
  2. liquid paint masking
    By helpmeout in forum Vectric
    Last Post: 10-04-2013, 02:57 AM
  3. VCarving Masking question
    By jburks in forum DIY CNC Router Table Machines
    Last Post: 05-08-2012, 03:32 PM
  4. masking film
    By 1ctoolfool in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2009, 02:42 AM
  5. Masking machined parts using vinyl
    By Brookway in forum Mass finishing equipment/media/strategies
    Last Post: 07-02-2007, 06:30 PM
