588,018 active members*
8,243 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > nema 17 and a3982,what lead screw and voltage
    Feb 2011
    hi
    i have a weird nema 17 motors and i live outside india so i cant get any fancy motors you use.
    12v
    0.3 amp per phase
    40 ohms per phase
    28mH
    3100 g-cm
    6 leads
    And i am using a3982
    i am using a pc power supply.12v
    So from what i have read that 40 ohms is too high
    on my poorly (have friction and lead screw whip "wobble issues)built mantis cnc with 15 tpi i cant get more than 15mm/min
    I am buildin a new cnc based on zen toolworks and my own chages to ensure least friction. what should i do with motors?
    give more voltage or not.
    And also i cant decide the pitch of lead screw and material for bearing. I am using direct or helical coupling,as i have access to lathe.
    Please help
    thanks
    Feb 2007
    498
    those motors and the fact your using 12 volts you wont have any top speed so i suggest
    a lead screw with more pitch,i would use 1/2-10 acme single start rolled lead screws,very cheap and you have a lathe so you can turn the ends down and make your own,as far as the nuts go you can find cheap ones on ebay, $5 dollars each and they mount real easy
    Feb 2011
    so with better motor i can run it on 12 v. And the resistance is problem right ?
    I am trying to replicate zen. i cant believe with 20tpi that machine can run on 300mm/min. Is it there motors or mechanical.
  1. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  2. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  3. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  4. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 02:49 PM
  5. Ball Screw and Lead Screw
    Last Post: 11-21-2003, 03:06 PM
