603,858 active members*
7,498 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > G83 - setting a speed of returning from the hole?
    Jun 2008
    5
    Hello, can anybody advice me please, how can I change a rapid speed of returning the drill from the hole in cycle G83? When the drill is returning from the last peck to the R position, the speed is so fast that machine is pretty much "shaking". And does anybody know which parameter sets this limit of speed for the each one of axes.
    Machine - Doosan Puma TT1800SY, Fanuc 16i TB,
    Thank You for answering
    Jun 2009
    195
    the controller has a rapid over ride right ? if so turn it down . I would look of any know-en problems like the z adapter between the servo and screw getting loose (like a fadel) other then that the machine should be made to run like that .
    Feb 2006
    1792
    Specify a lower rapid traverse rate. On 0i it is parameter 1420.
    Dec 2008
    3216
    Program it long hand, no G83
    it can also be used as a sub, for multiple holes
    ie
    Code:
    G1 Z-20. F100.
    Z3.
    Z-19.5
    Z-30. F100
    Z3. F2000
    Z-29.5
    Z-40. F100.
    Z3. F2000.
    G0 Z50.
    Jun 2008
    5
    Problem solved
    Thanks to everybody for help, I checked that #1420 and compared value to the machine catalog data and find out there were set a maximum (40m/min). Mira
  1. Setting up motor speed and all
    By lilimike in forum Mach Software (ArtSoft software)
    Last Post: 08-24-2010, 07:15 PM
  2. Setting inch per minute cutting speed
    By Edwardo in forum DynaTorch
    Last Post: 06-03-2009, 03:21 PM
  3. Determining "speed hole" spacing and size? (weight saving cutouts)
    By douglasco in forum Mechanical Calculations/Engineering Design
    Last Post: 08-04-2008, 09:26 PM
  4. Returning a new machine.
    By SIG in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2008, 08:27 PM
  5. Returning to 0,0,0
    By planekrazie in forum Mach Mill
    Last Post: 07-19-2007, 11:28 PM
