586,076 active members*
3,843 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Potentiometer on Huanyang control panel?
    Oct 2010
    93
    There seem to be some Huanyang VFDs with a "speed dial" potentiometer on the little removable control panel, and others without.
    Mine came without but had the markings of its scale on the panle decal.
    I opened it up and sure enough, the panel is actually dirlled behind the adhesive decal AND it has all connections and holes for one on the PCB.
    I would REALLY like someone to unscrew the back of theirs WITH dial and tell me the resistance value (or codes) on the potentiometer PLEASE:cheers:
    Thanks!
    Joe
    Joe in Aus
    24221
    Normally VFD speed pots will operate anywhere between 5k and 10k, make sure you get a Linear not logarithmic type.
    Al.
    Albert E.
    Oct 2010
    93
    Al.
    Thanks Al. I am aware from the VFD manual that the EXTERNAL pot should be 10k, but the pot I'm asking about is in effect INTERNAL.
    I guess I should just get one and try it - I can always unsolder it again
    Joe
    Joe in Aus
    Oct 2010
    93
    OK, I did it!
    Took a little while to get a 10k linear potentiometer that fitted the holes and mounting points on the PCB inside the little control panel.
    It works nicely - although a little mysteriously:
    Firstly, I had to acutate it by setting the jumpers next to the external connector strips to 'Potentiometer on "kneading board" ' - that's what the manual calls the "Touch panel".
    Next, I had to set Pd002 (the source for frequency control) to 1 "external" - go figure.
    Then I had to experiment with Pd072 and Pd073 to set the starting and end frequencies for the potentiometer - opposite to what the manual says. Lastly, while Pd073 is actually "obeyed" to start the potentiometer, Pd072 is not. I ended up setting it to 250.00 (Hz) to get a full pot deflection of an indicated 140Hz.
    But that's all OK. It works nicely!
    Thanks for the help.
    Joe
    Joe in Aus
    May 2005
    925
    Excellent, will do the same to mine next week. Thanks for the mini howto
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
  1. Agiepuls 30 control panel help
    By beadude in forum EDM Discussion General Topics
    Last Post: 02-04-2010, 06:48 AM
  2. Lathe control panel
    By frogeye in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2008, 02:31 PM
  3. Control Panel Cut out
    By scruffyjones48 in forum Employment Opportunity
    Last Post: 08-03-2008, 09:47 PM
  4. T32 Control Panel Lock up
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2008, 10:59 AM
  5. My DIY control panel
    By DennisCNC in forum Community Club House
    Last Post: 10-03-2006, 04:24 AM
