603,418 active members*
3,185 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Mar 2011
    Sinumerik 810M buttons do not respond
    I have old Reichenbacher ranc210am router with Siemens 810M controller. It was powered year ago then left. Now I'm trying to move it again. First problem is that Emergency stop release button light is on and I cant extinguish it, no button from that panel (Reichenbacher) show any respond only light test button. Second, almost all buttons from siemens panel do not respond, those which respond do different function than it should. Here is controller photos ImageShack Album - 2 images
    Feb 2009
    60
    your machine has emergency. you must control emergency line.
    and if dont work panel soft key you check connector between hmi plastic panel and hmi metal case.
    Jul 2010
    16
    Go to PROGRAM softkey, then press DIRECTORY.
    Look for any program inside.
    If no programs in the memory, the control don´t have machine data.
    Can you post a better photo for the screen MANUAL?
    Mar 2011
    I think that controller lost it program because of dead battery. This is video of controller [nomedia="http://www.youtube.com/watch?v=bZoU-pgUJWY"]YouTube - 100_7309.MOV[/nomedia] Now I searching for cable, think RS232 should do.
    Feb 2009
    60
    Quote Originally Posted by Alzen View Post
    I think that controller lost it program because of dead battery. This is video of controller YouTube - 100_7309.MOV Now I searching for cable, think RS232 should do.
    yes. your programs are deleted. do you have backup files and pc in program.
    Mar 2011
    I don't have backup program, but I working on that. Is there more tutorial like installation instructions than this?
    https://a248.e.akamai.net/cache.auto...structions.pdf
    Feb 2009
    60
    you must have orginal back-up. if you dont want these your work is hard. can you write email adress
    Mar 2011
    Mar 2011
    I found cheap RS232 cable Pin25:M - Pin25:M 1.8m LEMONA - Elektronikos dalys , and noticed that old computer motherboard has such connection for printer. It is possible to make connection with this?
    Feb 2009
    60
    your cable for siemens field PG. you can not use if you dont have 9-25 converter. and you must have pc-in program. do you have. but most importantly do you have system backup???
    Mar 2011
    Now, I'm waiting a mechatronic specialist to come from Germany, but it will take a while. Hope he will have programs. I have some floppys, but not sure about those. Click image for larger version.
    Feb 2009
    60
    how much money do you pay ?
    Mar 2011
    I don't pay My boss pay or use his connections.
    Feb 2009
    60
    maybe you could upload yourself by pc-in. did you try it
    Mar 2011
    We will do it both, because my boss wants to start it working as soon as possible.
    Sep 2005
    197
    Hi just want to join this. I conected to diffenent CNC controllers and you can make your own cable. you find your pin configuration here
    DNC software. CNC and DNC settings for Siemens - Sinumerik 810M.
    The old PC is a good choise. But you have to use the COM port not the Printer port. Normaly this is a 9 pin. Do not use a USB to Serial converter because you need 10V on the high signal but the USB to serial only gives you 5 Volt. this means you will probably do not have problems sending programs from you CNC controller to your PC but you will not be able to send data from PC to the CNC controller
    I will try to connect to a Sinumerik 810M to take a backup. Anyone know if there is a easy way to take a full backup. Programs, PLC program and Machine Data??
    Feb 2009
    60
    I will wite as soon. wait pls...(group)
    Feb 2009
    60
    5010 xxxxx000 (for PLC 100)
    5011 11000111 (for 9600 baud)
    5012 xxxxx000 (for PLC 100)
    5013 11000111 (for 9600 baud)
    5014
    5015
    5016 00101000
    INIT PARAM MENU
    __________________________________________________ ___
    DEL LOAD DEL LOAD LOAD
    PMCN PMCN PMAP PMAP PMCMU
    I never use LOAD PMCMU. because sometimes making problem. when you upload and download.
    this is not HDD. You loading in RAM. After the load PMCN you must format Mem Util and Prog Piece. If you dont format this. you can not use all RAM for load.
    Sep 2005
    197
    the Parameter settings you listed here I belive is with 9600,7 databits,even parity and 1 stop bit. That worked for me
    I see that on the aggsoft hompage it says
    Parameter 5011= 11110111 (9600, even parity,2 stop bits)
    Parameter 5013= 11110111 (9600, even parity,2 stop bits)
    I had the parameters that you wrote so I did not changed the parameters. Just used Hyperterminal and downloaded everything I managed to download
    Sep 2005
    197
    I downloaded
    ToolData
    ZeroData
    COMMData
    PARTPROGRAM (Main and sub)
    PCDATA
    Is it possible to download the PLC program also?
Page 1 of 2 12
  1. SINUMERIK 810M - 7024 error
    By rliovic in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-23-2011, 04:20 PM
  2. Sinumerik 810M - error 2087
    By hartan in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 01-02-2011, 12:09 PM
  3. Sinumerik 810M MD364* MD368* problem!
    By steva.vojnovic in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 11-27-2010, 12:26 PM
  4. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  5. SINUMERIK 810M GA1
    By amo in forum CNC Machine Related Electronics
    Last Post: 11-17-2009, 09:58 AM
