603,333 active members*
3,556 visitors online*
Results 1 to 13 of 13
    Nov 2005
    Question Supercam gone?
    Any recent development on SuperCam?
    I have an old DOS version that still works, but the computer hardware is getting suspect and I am wondering what kind of upgrade path to take.
    Is there a way to run my Supertech stepper system with another control software? (I'm not sure if there is a 'key' or something that might prevent it from working.)
    Corey
    Sep 2010
    33
    You can probably use Mach3. You will need a CAM software to generate the gcode as well. Supercam combines both cam and contoller software. Give Dennis a call and he should be able to help you. He has a configuration file for Mach that makes setup alittle easier.
    Biss
    Nov 2005
    Thanks.
    I shot Dennis an e-mail. Haven't heard back. Cruising his super-tech site I noticed that there is no prices or way to order anything...
    Will try and call him this week.
    Sep 2010
    33
    The following is a link to the configuration file (bottom right of page, zip file)
    Parallel Port CNC Desktop Taig Micro Mill Complete Three Axis Setup
    Also here's the link to the Mach3 control trial software
    ArtSoft USA - Software Downloads
    I have been using a 10 yr old supertech controller with Mach 3 sucessfully for several months now. He has some other options to get SuperCam to run on newer machines (Xp and newer); it is called a CamPod. You can check that out on his website as well.
    Biss
    Apr 2019
    Hey guys I know it's been a long while since this has become a topic but I've ran into somee issues. I purchased a KAM plasma table with the Supercamxp software on it and neither of the businesses are still operating..... Can you point me in the direction of some technical support when it comes to software changing using the supercam controller and stepper motors? Any help would be appreciated!
    Feb 2020
    8
    Quote Originally Posted by Kurokikustoms View Post
    Did you ever find anything? I have an older machine successfully running supercam as well. Looking to move to vcarve and out put to match 3.
    Apr 2004
    5948
    Re: Supercam gone?
    Are you sure those are stepper motors? As I recall, SuperCAM machines used servos.
    Andrew Werby
    Website
    Feb 2020
    8
    Quote Originally Posted by awerby View Post
    I have servos on mine. With regards to supercam. I have the original instruction booklet if any one has any specific questions. I have not scanned it in yet but that could be an option in the future.
    Mar 2012
    Re: Supercam gone?
    Quote Originally Posted by jasonGO View Post
    Anyone get results upgrading from Supercam to Mach3. I tried to get setup info but Mach3 says they can't help,. I tried Microproto and they offered nothing.
    My Taig mill had Shimano steppers and so far, I haven't got them to move with a UC100 and Mach3
    Feb 2021
    Re: Supercam gone?
    That would be incredibly helpful. I'm trying to set up my friends table. It came with an old supercam xp disc, but all the tutorials and config stuff on the disc takes you to flash links that browsers no longer support. I can't even install it on any other computer to look at it as the disc is so old and scratched up it freezes on installs.
    Feb 2021
    Re: Supercam gone?
    Re: Supercam gone?
    Could i get a copy of the supercam manual please?
    Nov 2011
    9
    Re: Supercam gone?
    YES SURE WHAT DO YOU NEED , I CAN HELP YOU
    ANDREAS
  1. What is SuperCam and SuperCamXp
    By Dennis Bohlke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-02-2023, 10:42 AM
  2. SuperCam/Taig Need help
    By swartzhund in forum Taig Mills / Lathes
    Last Post: 12-30-2005, 01:43 PM
  3. CNC Taig/SuperCAM Jogging?
    Last Post: 11-04-2005, 02:58 PM
  4. Anybody using Supercam software
    By landart in forum DIY CNC Router Table Machines
    Last Post: 01-27-2004, 09:17 PM
