587,777 active members*
2,529 visitors online*
IndustryArena Forum > CAM Software > CamBam > Adding tabs to existing file
    Jan 2010
    10
    How can tabs be added to an existing file. Thank you. Bud
    May 2010
    327
    Bud -
    do you mean an existing CAMBAM file? Pretty easy if so. Select the appropriate machining function, open up the tabs option (advanced panel not basic), and setup your tabs. I use the automatic tabs and then just move them to where I'd like them.
    Noob here...hope I'm helping.
    Bill
    Jan 2010
    10
    Thanks, Bill. Bud
    May 2010
    327
    Hope that helped, Bud. Happy to send you a sample file with tabs if that helps too.
    Bill
  1. adding 4th axis: need to match existing servo?
    By BiggerHammer in forum CNC Machine Related Electronics
    Last Post: 01-14-2010, 01:35 AM
  2. adding 4th axis to an existing mill
    By BiggerHammer in forum Uncategorised MetalWorking Machines
    Last Post: 12-25-2009, 04:18 PM
  3. Turning existing dwg file into 3D (solidworks)
    By Tony888 in forum Solidworks
    Last Post: 06-19-2009, 04:28 PM
  4. adding clearance to existing model
    By Gncc50 in forum Mastercam
    Last Post: 01-08-2009, 05:48 AM
  5. Adding Tabs With MasterCam V9
    By mmcclain02 in forum Mastercam
    Last Post: 01-20-2006, 08:53 PM
