586,719 active members*
3,196 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > how to activate the tailstok while the lathe is running.
Results 1 to 13 of 13
    Jul 2010
    Mostly i am working on a lathe Okuma LB 15,controll OSP 5000L-G.
    Now i want Turning a long part with a small diameter.
    I want turning the frontside and then the center gripping on the face and i want turning the face to the chuck.
    It will be with M20(tailstock barrier off) M56 (tailstock advance) and M55 (tailstock Retract).
    But what is the parameter to activating the tailstock?
    Who can help me?
    Dick.
    Jan 2008
    575
    "TAILSTOCK CONDITION" needs to be set to 1
    Robert
    The beaten path, is exclusively for beaten men.
    Jul 2010
    Quote Originally Posted by littlerob View Post
    Robert
    Yes i now,but i dont now the name for programming this.
    Dick.
    Feb 2009
    6028
    Not a programming thing, you set the tailstock on in the chuck setting page. You may still need to release the tailstock interlock in the program, m code, don't have the book here. I thought it was m157.
    Mar 2010
    Hi all,
    Tried this myself over a year back.
    Enabled the tailstock in the parameter screen, then in my program had it face the part, centre the bar and advance the tailstock before continuing.
    Well, I couldnt get it to do that. It kept requiring the center in place before the cycle would start no matter what I done.
    So gave up as time was an issue and pre-faced and centered all bars on another machine and just loaded each into the okuma and advanced the center before running the program.
    Ours was also a LB-15 with OSP 5000LG control.
    Cannot test anything out for you at this time as our machine has been sat for the last 16 months out of action with a failed bubble memory card, so its a 4 tonne paperweight at the moment :-)
    Would still like to hear a solution to the OP 's inquiry tho, incase our machine gets fixed.
    Rich.
    Jan 2008
    575
    Ha, I found this interesting, apparently I had the same question some time ago.
    http://www.cnczone.com/forums/okuma/...tock+condition
    Robert
    Feb 2009
    6028
    You need to program m157 if you have the tailstock on but retracted. M156 puts it back to normal when you advance it. Interlock release.
    Apr 2006
    822
    Robert
    Good to see that you remembered your previous post!
    Did cover it then I thought...
    Well linked Robert.
    Cheers
    Brian.
    Jul 2010
    Quote Originally Posted by Rich_UK View Post
    Hi all,
    Rich.
    I do this on the same manner.
    But i want to do this and center to do advance while the program is running.
    Therefor i must the tailstok condition set by the program,i think with a parameter.
    Dick.
    Jul 2010
    Quote Originally Posted by underthetire View Post
    Thanks,I shall try it ,may be tomorrow.
    Dick.
    Jan 2008
    575
    Quote Originally Posted by broby View Post
    Well linked Robert.
    Cheers
    Brian.
    There are two funny things about this thread,
    one- I actually forgot that I was the one who started the other thread!!
    two- the O.P. here has the answer right in front of him and hasn't seen it.
    Robert
    Apr 2006
    822
    Robert
    Haha, Yep you have the spot on mate!
    Jul 2010
    Lightbulb
    Your're richt,today I tried this,its work out.
    Early,I did try also,but I did'nt now the tailstock condition must to be set by hand.
    I am glad,many thanks,
    Dick.
  1. How do I activate the HPCC???
    By jsmith2232 in forum Mori Seiki Mills
    Last Post: 02-24-2011, 04:39 PM
  2. New mini-lathe is not running
    By Smertrios in forum Benchtop Machines
    Last Post: 06-20-2010, 01:29 AM
  3. couldn't activate the debugger
    By Bala in forum Post Processors for MC
    Last Post: 04-05-2010, 12:09 AM
  4. Activate editing expansion for 21M
    By edufer1 in forum Fanuc
    Last Post: 06-11-2008, 10:47 AM
  5. Anyone running converted Lathe?
    By jinu117 in forum Syil Products
    Last Post: 11-13-2007, 09:05 AM
