586,089 active members*
3,745 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Cutting stainless steel on a router
    Aug 2008
    1166
    I'm bored waiting for fea to run on a frame design, so here's a 'what I did last week' post - I cut stainless steel using my router. Pics are below. I was working on welding oxygen sensor bungs (threaded bosses) to the stainless exhaust pipes on my motorcycle. My first idea was to drill the required holes in the pipes with a hole saw, so I got one at the hardware store. I made a test cut in a tube of 304 I'd bought to practice on before I tore into my bike's pipes. The hole saw melted on the stainless. Must have got a crappy one... Alright, so it was late at night and I want to make some holes. I ran inside, programmed a quick hole pocketing operation and put my pipe on my router. I cut 0.005" per pass at 10ipm with a 2 flute carbide endmill. It took about 20 minutes to cut a 3/4" hole (mostly due to the pipe being round, so I had to cut about 0.2" deep). It turned out nice. I'm not saying the surface finish is amazing, but the hole was the right size and considering I was welding to it, perfectly serviceable. The last pic is the finished part. Don't judge my weld to harshly - I'm still a beginner and this was my first stainless work ever.
    I couldn't figure out how to fixture the second pipe on my router, so I hacked a hole out with a dremel tool and grinding wheel and then made it round with a carbide burr in a foredom. That was probably faster than the router but not quite as fun.
    Attached Thumbnails Attached Thumbnails P1010001.jpg   P1010004.jpg   P1010006.jpg   P1010007.jpg
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Jun 2005
    176
    I'm impressed :-)
    I have seen another 3 axis machine cutting steel, mild steel, the guys programmed it to go in and just take a whiff off each pass. The cutting would've taken hours! The big issue is tool pressure going into such a hard material.
    Most woodworking machines can't take the pressure and lack the rigidity to do practical cutting.
    Aug 2008
    1166
    That's how I do aluminum cutting on my router - it takes hours and the finish still usually isn't great, but good enough. I usually go more like 0.010" per pass at up to 20ipm on aluminum though. I was surprised it did as well as it did on the stainless.
    I always believe that almost anything can be done , it's all in the approach
    this was my experiment , [nomedia="http://www.youtube.com/watch?v=s1ftb_cA4nE"]YouTube - cutting steel[/nomedia]
    it was programmed to 120ipm but for the initial slot through I dropped it to 60 , part way thru the pass back i bumped it up to the 120 (1/2 way thru the vid) , it takes only .01 engagement per loop but as you can see 120 ipm can remove material quickly ,
    it was the same deal as yours , not a perfect finish but not to shabby either
    the only problem that I found was that there were fine needle like chips everywhere
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  1. Cutting Stainless Steel
    By rbmedic75 in forum PlasmaCam
    Last Post: 11-10-2010, 09:04 PM
  2. CNC Stainless steel cutting
    By PakoNG in forum Want To Buy...Need help!
    Last Post: 02-11-2010, 10:34 PM
  3. Cutting Stainless steel on a CNC Router (MultiCam)
    By routski in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:00 AM
  4. cutting stainless steel
    By YANKS_RINKS in forum MetalWork Discussion
    Last Post: 03-21-2008, 10:43 PM
  5. Cutting stainless steel
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-25-2005, 11:14 PM
