603,795 active members*
2,823 visitors online*
    Nov 2007
    69
    power outage restart
    just had a power cut, program and machine stopped thru a cut...
    how do i restart the machine to clear the job before power up restart ie: 'y' axis only
    how do i do this if say i had a slitting saw and it was stuck in the job?
    thanks
    HAAS TM-2
    Mastercam X4/X5 - Level 3 - Solids @ work / HLE @ home
    Dec 2010
    154
    Before you turn it back on, close the e-stop. Now power back up and clear all alarms. "Single axis return" "Y", if that gets you out of the work piece, then "X" then "Z""....
    I had a power out once and it burned a fuse, might have to deal with that too.
    Jul 2005
    12177
    Quote Originally Posted by riverracer View Post
    thanks
    Setting 53 JOG W/O ZERO RETURN is your friend in a case like this.
    Power the machine up BUT DO NOT PUSH Power Up/Restart to home the axes.
    Go to Settings, find 23 and turn it ON. Now you can jog any of the axes VERY CAREFULLY because you have no protection if you start jogging it into a hard stop.
    Once your tool is clear and the Z axis can lift without damaging anything push Power Up/Restart.
  1. Power Outage ?
    By Phishaholic in forum Tormach Personal CNC Mill
    Last Post: 06-29-2009, 11:15 PM
  2. Replies: 2
    Last Post: 05-21-2009, 10:16 PM
  3. Restart from power failure.
    By Farproducts in forum Excitech routers
    Last Post: 04-01-2009, 12:37 PM
  4. Restart
    By jhersh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2008, 02:20 AM
  5. Power outage during machining
    By walter in forum DIY CNC Router Table Machines
    Last Post: 08-02-2005, 03:13 PM
