603,870 active members*
7,054 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > 3D carving .. foam material ..
    Jun 2010
    40
    Exclamation 3D carving .. foam material ..
    I have bought some new 3D designs to carve on wood using my CNC router.
    But I would like to try the designs on some low cost , soft material before starting on my costlier wood. I read that "High Density Foam" can be used for this. Where can I buy these from and what sizes are these material typically available?
    Can some kind of wax be used for this?
    regards
    Feb 2009
    2143
    You can get 2" foam board at Home Depot in 4'x8' sheets, under $30. Cut them to rough shape, glue them together if you need them thicker, and start cutting!
    Owens Corning Foamular F150 2 in. x 48 in. x 96 in. Scored Squared Edge Foam - 270895 at The Home Depot
    Aug 2003
    329
    The high density foam you are talking about is called Sign foam and it is expensive. More expensive than wood. However you can use foam from Home depot. The blue foam is from DOW and pink foam is from Owens Corning.
    It is also known as HDU which I believe stands for High Density Urethane???
    Bill
    Apr 2004
    5950
    I'm not sure if they have Home Depots in India
    But what those folks were advising you to look for is generically called EPS (Expanded Poly Styrene) foam. It isn't particularly high in density, but it is cheap, and it's sold as insulation for buildings. High-density urethane foam cuts beautifully, but it's pretty expensive.
    Machinable wax is often used to prove patterns before cutting them in more precious materials. It's available here, but I'm not sure about in India. You can make it from regular candle wax (which we call "paraffin" but you may not) by adding about 1 part LDPE (Low Density Polyethylene - it's used to make plastic bags) to 2 parts wax by weight in an electric pot (be careful doing this and keep the pot lid handy, since it can overheat and start a fire.) The nice thing about this wax is that it can be re-melted and recast into new blocks pretty much indefinitely, as long as you don't contaminate it with other materials.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Feb 2009
    2143
    Oops, missed the India thing. I am sure they have rigid foam there too, but maybe not Home Depot...
  1. Foam Carving CNC Router
    By Alan_c in forum DIY CNC Router Table Machines
    Last Post: 05-26-2009, 10:59 PM
  2. CNC for Ice carving!
    By asandoval in forum Community Club House
    Last Post: 03-20-2009, 06:59 PM
  3. Looking for a machinable foam or flexible material.
    By VTX in forum Material Machining Solutions
    Last Post: 06-09-2008, 01:12 PM
  4. 3D topographical map routered out of foam foam
    By 3Dmap in forum CNC Wire Foam Cutter Machines
    Last Post: 08-26-2007, 01:55 AM
  5. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
