587,480 active members*
3,396 visitors online*
    Jan 2009
    34
    Bridgeport y axis servo mount
    Have a Bridgeport Boss 4. Wanting to upgrade control and go to servos. My question is on the Y axis the servo motor doesn't fit. I would like to avoid mounting the motor sticking out the front and instead make a mounting plate that slants down 45 degrees in order to mount the servo close to the X axis servo. Is the original configuration that holds the Y axis stepper motor also the bearing housing for the Y axis ball screw? Has anyone done this before?
    Also when using servos is it better to use the 1:1 pulley ratio or what?
    1121
    different models have different amounts of clearance in the knee casting. I think I would expand the hole with a grinder or find a new servo motor before I reengineered the y axis
    15362
    kosmo
    It would have to be a very big servo not to fit, If the system was 1/1 then stay the same & yes the front housing has the bearings in it that support the ballscrew
    Attached Thumbnails Attached Thumbnails Bridgeport-1.jpg   Bridgeport-2.jpg   Bridgeport-3.jpg
    Mactec54
    Jan 2009
    34
    Smile
    THANK YOU, THANK YOU, THANK YOU, for the replies. Any chance on getting the make and model of the servo pictured by mactec54. I was concerned about this do to the responses that the Keling servo's were just to long to fit.
    15362
    kosmo
    The servo's in the photo's are Yaskawa sigma II 850w, the servo to look at are from DMM
    they will work very well for your machine
    Motion Control Products - DMM Technology
    Mactec54
  1. Replacing box mount receptacle connector on servo motor
    By gandp in forum Servo Motors / Drives
    Last Post: 02-27-2011, 08:34 PM
  2. Add Z-axis to EZ-Trak need servo mount
    By ataylor_316 in forum Bridgeport / Hardinge Mills
    Last Post: 10-01-2007, 03:49 PM
  3. One way to mount a VFD on a Bridgeport - PICS!
    By mxtras in forum Bridgeport / Hardinge Mills
    Last Post: 11-27-2006, 04:07 PM
  4. Servo Mount ?
    By Ken_Shea in forum Servo Motors / Drives
    Last Post: 06-14-2006, 03:24 PM
  5. How would you mount a servo to this Rotary Table?
    By replicapro in forum Uncategorised MetalWorking Machines
    Last Post: 07-05-2004, 10:37 PM
