603,415 active members*
2,965 visitors online*
IndustryArena Forum > Community Club House > set-up & operation sheets
Results 1 to 10 of 10
    May 2003
    37
    Question set-up & operation sheets
    I need help on setting up a time keeping system in a proto-type shop. Does any one know or have sample sheets I can look at. Thanks, Bill
    6855
    Are you looking for a excell sheet or a program to track time? You could use a program like Quicken that has time logging per job I believe.
    202
    I use a time tracking sheet that you manually fill in I will try to get it and put it up tomarrow.
    May 2003
    37
    Right now i am manually filling in my time sheets this takes forever , the problem is many work orders same part number, also there is only one job that is a money maker in the shop.
    What the owner is trying to do is get a grip on what it cost to run the proto-type side of the shop. I asked company to put something on the computer so I can scan in. We have hand held scanners so it should be no problem. Can or is it possible for excell to scan ?
    Thanks, Bill Johansen
    Apr 2003
    1876
    It is possible to do it with excel but you'll need to write the macros for it. I believe the winsock control will do it, but I"m not sure of how it would be coded.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    May 2003
    146
    The simplest form of barcode reader is called a "wedge". It is installed between teh keyboard and PC. It shoots caharacters that would otherwise come from the keyboard. In this wsetup, essentially any thinkg you do with keystrokes can be done with the scanner. Additionally some units allow programming of macros in the scanner itself that can extend this functionality. As Rekd said, the addition of some macros in your software is an easy way to prompt for and manipulate scanned data.
    CAM
    I will post more regarding the initial question when I have a little more time, just got a call, gotta go.
    Wee aim to please ... You aim to ... PLEASE.
    May 2003
    37
    Talking set-up & operation sheets
    Thanks for all of the help, the company is going to let me use some software called VISUAL MANUFACTURING. It will take some time for them to set up, but is better than tons of paper work.
    May 2003
    84
    Hey this is timely! I am making up some control/operation/setup sheets for our shop now. Some new ideas would be mighty helpful. Hey Jimmy are you going to put up your tracking sheet? Anyone else have any to show?
    Fish
    Apr 2003
    1876
    Fish
    Here's a look at my Micro$oft Access setup sheet system.
    This is the UI, notice it will load data from a setup sheet generated in Mastercam, and import it into the Access database.. and import pictures. You can also transmit the file to the machine right from Access.
    Apr 2003
    1876
    And here's...
    ... the printable setup sheet...
    'Rekd
  1. Rapid to (# set by Parameter) What's yours?
    By Scott_bob in forum G-Code Programing
    Last Post: 09-01-2021, 06:05 PM
  2. Operation Data - At Op End
    By wjbzone in forum GibbsCAM
    Last Post: 09-24-2004, 01:30 PM
  3. How to set up Tool Offset in MACH2?
    By High Seas in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2004, 06:54 PM
  4. Cost and feasibility of a new operation.
    By Laff Riot in forum Casting Metals
    Last Post: 08-23-2004, 07:15 PM
  5. Cutting Aluminum Sheets
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 05:12 PM
