586,032 active members*
2,896 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kiatmura Jig 7 Unclamp Cylinder
    Jun 2003
    70
    Cylinder is not pushing drawbar far enough release pull stud.
    Construction of cylinder reveals that it is an air oil force multiplier. Perhaps oil is low so it does not develop full travel.
    Any ideas on adding oil?
    Jim
    Jim Short
    www.tahlinc.com
    Jun 2003
    70
    There should be a plastic line that comes down from the top left of the head stock to a fitting on the side of the cylinder.
    Jim Short
    www.tahlinc.com
    Jun 2003
    70
    This 30 year old cylinder has molded seals that we did not even try to replace. We added a once of brake fluid to swell the seals and stopped the leak. Been good for two years so far.
    Jim Short
    www.tahlinc.com
  1. unclamp pallet for FH-5800
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2011, 02:31 AM
  2. ST 20 - C axis unclamp
    By SurfRunner in forum Haas Lathes
    Last Post: 03-07-2011, 05:31 PM
  3. Clamp Unclamp Problem VMC
    By 24kilo in forum Fanuc
    Last Post: 01-18-2010, 11:44 PM
  4. Tool unclamp fault
    By IMlearnin in forum Daewoo/Doosan
    Last Post: 06-08-2007, 02:40 AM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
