Can anybody help me where to get step time, step space, direction hold & direction setup for RTA PAVIA SDC 05 motor drives? help me plzzzz
Hi
You will find all the info you need on this post.
http://www.cnczone.com/forums/calibr..._32-65vdc.html
Thanks mkc2,
in the post, you said that you use sherline 1/2 pulse mode setting. so,
step time = 1000 ns
step space = 6000 ns
direction hold = 24000 ns
direction setup = 24000 ns
refer to this link
EMC Documentation Wiki: Stepper Drive Timing
is that true?
Sorry but I dont understand these timing settings, I dont see these any where on my setup.
I dont use the same drives as you ,but they would be similar to your setup.
My drives are the GMD-02 RTA.
I use Mach3.
You can download mach3 and have a look at the settings, it will give you the full version but only allow 500 Gcode lines untill you buy the licence key.
Some settings to get you started in mach3.
