586,060 active members*
3,709 visitors online*
    Jun 2010
    Angry inconsistent toolpaths
    I have a very small hobby cnc machine. it will not run consistent parts. Please check the pictures I have attached. I have my toolpath generated to cut a wagon wheel - must be correct b/c I was able to cut one perfectly. But while trying to cut a second or third, the machine started following a path of it's own choosing.
    I start in Corel Draw, then to Vectric Cut 2D, then to Mach3. I am quite certain it is not a physical, mechanical problem. Does anyone know if there is a setting in Mach3 (or any of these programs) that I may be overlooking that could cause this?
    Attached Thumbnails Attached Thumbnails 100_1601.JPG   100_1602.JPG   100_1603.JPG
    Aug 2005
    597
    Hello 5thtry,
    If you could email the Cut2D .CRV and also the Mach3 GCode files to me I'll take a look.
    Tony
    your stepper motor(s) might be missing counts. return to home after each part, some machines will check for lost counts when you do this. check the machine for mechanical binding (remove the motor or drive belt & turn the screw by hand). in the program move to a known location (center of the part or XY origin) and do a visual check before starting the cut.
  1. Inconsistent Haas 300 bar feeder
    By Dweezle69 in forum Haas Lathes
    Last Post: 07-14-2011, 06:42 PM
  2. Correcting inconsistent backlash
    By alex781 in forum Mach Mill
    Last Post: 06-27-2010, 08:54 PM
  3. Inconsistent EPS Cutting help needed
    By X-15 in forum CNC Wire Foam Cutter Machines
    Last Post: 01-07-2010, 01:18 AM
  4. Inconsistent DRO Values. HELP Please!!
    By willio in forum Shopmaster/Shoptask
    Last Post: 06-11-2009, 10:46 PM
  5. Inconsistent Spindle Brake?
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 09-22-2007, 02:33 AM
