Hello, all -
As you can see from my post count, I'm new around here. Looks like a huge trove of information if one can sift through it all to find the relevant nuggets. I'm looking forward to becoming a regular.
In the meantime, I need some advice. I recently purchased the plans for the 24x48 machine from
Solsylva CNC Plans~ Home Page. I'd like to build it with a 24x96 table. For the time being, 100% of what I do with the completed machine will be to cut flat parts out of sheet stock (MDF and/or plywood), mostly to use as templates for parts being made in my workshop out of solid hardwood. I'm sure that as I get time under my belt with the machine, I'll come up with other uses for it, but for now, all I want is to be able to make through-cuts in sub-3/4" material.
It appears from reading the manual that leadscrews are the way to go (as opposed to belts, chains, or rack & pinion). The manual also mentions HobbyCNC and Xylotex, Mach3 and TurboCNC.
Before I go any farther (i.e. start cutting up lumber and visiting the hardware store), I just want to get a reality check from some of you guys that have already gone down this street. Are HobbyCNC and Xylotex the only ways to go? What about Mach3? I ruled out TurboCNC because it doesn't appear to have been updated in three years; I would like to know if there are other (better) alternatives to Mach3. It may be the bee's knees, but it looks like Ray Charles did it at night. I know the interface can be customized, but come on - I don't want to design software, I want to butcher wood.
That having been said, I'm a bit confused by the other software options out there. My workflow (for now) will be AutoCAD 2D drawing to CNC machine. In the future, I will surely add Rhino and/or SolidWorks to CNC machine. And it just occurred to me - does any of this software perform panel layout (i.e. sheet goods optimization)? If not, how are you handling that task?
Thanks in advance for your input. I'm sure the answers given will provide me with a whole new set of questions, but I've gotta start somewhere.
