603,818 active members*
4,850 visitors online*
Results 1 to 8 of 8
    Aug 2005
    93
    What would you call this?
    A machine where you put a part into it, it precision scans the part then out puts an accurate 3D model to a control operator that will then work with the part in a CAD program, then render all the changes to the part into G-Code and start milling?
    Might be a good tool for reconditioning parts, as well as inspecting them.
    May 2004
    290
    A 3-d scanner?
    Apr 2005
    a digitizer?
    Aug 2005
    93
    Well... maybe its a two in one machine, but something scanned the part in, and while the part was still bolted down switch over to end mills and start milling the part after the operator has made some modifications to the part.
    Where it eliminates the step of positioning and centering the headstock because the mill already knows where the piece is in relation to its self.
    Sep 2005
    91
    For Real
    reverse engineering
    Aug 2004
    2849
    Well it's a CMM (corodinate measuring machine....or something like that), CMM's also have a digitizing accessory which you can use to give the shape/profile of an object.
    That data you'll have to feed into a CAD for drawing, and a CAM ....etc.
    Mar 2004
    156
    i called it CNC-3D-Duplicator
    Nov 2004
    320
    cool stuff
    http://www.faro.com/products/scanarm.asp
    we use one of these to check machining & reverse engineer stuff
    scan the part do a fit to the model then it highlights the inacuricies
