586,103 active members*
3,866 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM-3P Boot Error
Page 1 of 2 12
Results 1 to 20 of 37
    Jun 2011
    36
    Unhappy Hurco KM-3P Boot Error
    hi,
    I have an Old Hurco KM-3p Milling Machine, before it was working fine,
    but suddenly when i started the machine , its not booting,
    the cursor is blinking on left corner.
    the personality board power light is green, memory card is green.
    please help me out to solve this problem.
    I am from Pakistan,
    If any one can give me Buddy Maughan's mobile no. with the international code I will be highly obliged.
    i have tried to run the Diagnostic, and it shows the
    CRT communication Failed.
    can any one please help me out in this regard.
    regards
    Feb 2010
    163
    Which control does the machine have - B, BX, Ultimax?
    If it's ultimax read this thread, second post:
    http://www.cnczone.com/forums/hurco/..._max_2_no.html
    about replacing the MC1488 and MC1489 chips.
    Jun 2011
    36
    Quote Originally Posted by fasto View Post
    @fasto,
    Thanks for your Support, The Display came back, even my Right Graphics CRT was not working now its also working but there is another problem and that is the Keys are not working any HELP in this regard???
    Jun 2008
    1104
    Replace the P8255A on the CRT controller in the console.
    Jun 2011
    36
    I have also Changed the 82C55A, Now the Keys are working but the Screen is saying
    at the Top in screen
    **** Machine Configuration *****
    Maximum X Travel 0.00000 MM
    Maximum Y Travel 0.0000 MM
    Maximum Z Travel 0.000000MM
    Calibration Direction X Right , Y Back
    Now Keys and Screen are working, How can I got to Diagnostic mode again,
    I am very thankful to both of the guys to help me reach at this point, I am very hopeful that you guys can help me out to finish this problem
    best regards
    Jun 2008
    1104
    Enter the travel lengths fot each axis (x 609.6, y 355.6, z 127). Press the bottom softkey 'exit' then press enter 999 enter. Then press the bottom softkey again when it's booted.
    Jun 2011
    36
    now
    X=610.000MM
    Y=355.00MM
    Z=127.00 MM
    I press soft key of Exit than I press 999, than ENTER key, it seems to me the keys are not working properly because the Manual key is also not working . i have pressed several time enter key but no response.
    when I press exit key, it says again "choose appropriate soft key", it does not show the next screen.:drowning:
    Jun 2008
    1104
    You have to press enter then 999 then enter again.
    Jun 2011
    36
    yes dear I am doing the same.
    the cursor is blinking at the position choose the appropriate soft key.
    I pressed Enter 999 Enter . but nothing happens
    Jun 2011
    36
    Its DONE:wee:
    when I press x, y or z key it shows 1, 2, 3, and the num keys were not functioning well only no. 6 was working.
    I took a chance to reverse the Ribbon cable of the key board.
    than tried and its done.
    thanks Bloke!
    can you please tell me further how to make the backup of this software coz I have nothing. I and if possible Service Manual of it in pdf. format.
    I am very Much Thankful To you Again.
    best regards
    Jun 2011
    36
    Now there is another Problem!
    the main problem or fault on this machine is , its Y axis was problematic.
    when any job is placed. it works fine after 2 or 3 hours it damages from y axis.
    i thought its cooling problem as this department is very hot.
    i have placed a PVC 4" pipe from windows AC to Panel Fan.
    after that the problem come now after 8 to 10 hours.
    I have a feeling that may be in X, Y axis Card there is some kind of ADC chip has become week. can you please tell me which one this could be
    is it ADC0803. ???? or any other IC ???
    Jun 2008
    1104
    Swap the XY and ZSpin boards.
    Write down all the jumper and switch settings for both XY and ZSpin boards. Then swap the EPROMs between them and re-do the switches and jumpers. The spindle doesn't use the DAC.
    Jun 2011
    36
    yes i have done It. noted all the Jumper Settings and Swapped both the EEPROMs and
    after changing the settings
    placed the Zspindle card to X.Y Slot. and X.Y to Zpindle SLot.
    now when I press Calibirate and Start Key the X axis move wrong Side.
    and if Press + key it goes to - minus side.
    is there something I am missing still
    Jun 2008
    1104
    I think you must have missed a jumper on the board. There is one that determines axis direction.
    Jun 2011
    36
    I did exactly as you guided me, can you please guide me further ???
    Jun 2008
    1104
    I don't have the jumper numbers with me at the minute. I'll see if I can find them. For now, return the boards to their original condition.
    Jun 2011
    36
    still the same problem in X-Axis, Spindle is working Fine, Y-Axis is moving fine.
    But in X-axis, it is going opposite side. also the +, - keys are working opposite.
    i have Changed Mc1488, and MC1489 in Personality Board Too,
    is there any link from there ??
    i have changed 82C55A too, or This could be ..........??
    Jun 2011
    36
    I have Noticed One Thing!
    that Machine is again in " Machine Configuration "
    Have Managed to change the parameters in Metric system now its ok.
    X=610.000 MM
    Y=355.000 MM
    Z=127.000 MM
    Now after power up the machine, its in " Machine Configuration "
    If I press Soft Key " Exit "
    it goes to NEXT screen " INPUT "
    so, I how do I get out from This " Machine Configuration " Screen
    I have attached Both The Screens Pictures for details
    may be because of bad parameter settings X is moving Wrong side.
    Please guide me to put the values for XYZ
    Jun 2011
    36
    Now
    I have Replaced all the things back in original position as per your Direction.
    and than Tried enter 639 enter 0 enter, enter 999 enter .
    it rebooted and now at least, the + and - keys are working fine. only thing which is left is
    X-axis is moving in wrong direction at the time of calibration.
    but in manual it is working fine.
    Jun 2008
    1104
    Power the control off and on again. Press enter 100 enter.
    in the start page, set the calibrate direction for X to the opposite of what it is now.
    Press exit.
    Press enter 999 enter.
    Press the bottom softkey when it boots.
Page 1 of 2 12
  1. Hurco bmc 40 wont boot to config screen
    By inventor30 in forum HURCO
    Last Post: 11-05-2011, 01:16 PM
  2. Replies: 0
    Last Post: 11-12-2009, 03:25 PM
  3. Hurco won't boot up
    By Dave Rothermel in forum HURCO
    Last Post: 09-29-2009, 11:00 AM
  4. A2100/NT boot error
    By kentsui in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-14-2008, 10:44 PM
  5. Hurco ATC error
    By openforbiz in forum HURCO
    Last Post: 11-05-2007, 04:19 PM
