603,793 active members*
3,666 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help Needed Connecting a Fanuc Oi-Tc to an FTP client
    Jun 2010
    I have connected a new lathe to a PC via a router. I need to transfer files to it via an FTP client (in this case its Flash FXP).
    I have put in all the correct details for the FTP connection (IP Address, Port N0, Username and Password).
    I can ping the IP address and I get a positive reply but when I try and connect through Flash FXP it won’t connect! My laptop has Windows 7 on it as well. Not that it should matter, I’ve connected to FTP sites before on it using the same FTP client.
    Can anyone help?
    Cheers
    D
    Oct 2010
    87
    Use TYPSoft FTP server , choose the "without install" version.
    Jun 2011
    for win 7 also u have to enable the FTP in IIS settings. after that u can transfer the files thru FTP.
    Jun 2010
    Why should the ISS settings matter when I have been using FTP in the past.
    Cheers
    D
    Ensure that you set a user/password all in CAPS and set a home dir
    I use filezilla it is quite simple to set up FTP
    Also ensure your firewall for port 21 is switched off !
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
  1. Fanuc 10T Help needed
    By jasonladams in forum Fanuc
    Last Post: 04-21-2010, 09:50 AM
  2. Connecting Fanuc 11M via Serial Port
    By Tenretni in forum Fanuc
    Last Post: 03-08-2010, 03:48 AM
  3. beginning of letter to you client
    By Nemo1985 in forum Community Club House
    Last Post: 12-17-2009, 09:12 AM
  4. HELP NEEDED! FANUC 6M W/O G54
    By SINUMERIKO in forum CNC Machining Centers
    Last Post: 10-28-2008, 01:34 AM
  5. Help needed Fanuc 11-MA
    By Green Button in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2006, 07:59 AM
