586,102 active members*
2,620 visitors online*
    Mar 2006
    6
    Connecting Vacuum to Gerber Sabre
    Hi All
    I've purchased a second hand Gerber Sabre 408 router. It came with a vacuum generator that connects to the table. Unfortunately, it was disconnected when the machine was decommissioned 4 years ago. I can't find any documentation on how to reconnect.
    If anyone has one of these machines, would you mind letting me know how to wire it into the table. There is a seimens controller on the side of the router. I believe that this is somehow related to the vacuum pump.
    Thanks in advance.
    May 2008
    85
    We have ours wired to a separate switch. As far as I know there is no hookup to the control in any way.
    Don't know what the Siemens controller is for.
  1. Gerber Sabre 408 help...
    By crackstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2018, 01:29 PM
  2. Gerber Sabre 408 Lead screw and nut
    By fbrinc in forum Commercial CNC Wood Routers
    Last Post: 12-28-2011, 12:00 PM
  3. Evaluating a Gerber Sabre
    By ToolslingerNJ in forum Want To Buy...Need help!
    Last Post: 05-22-2011, 02:51 AM
  4. Running g-code on gerber sabre 408
    By precise graphix in forum G-Code Programing
    Last Post: 08-04-2008, 07:37 PM
  5. Gerber Sabre 408
    By Pasty in forum Want To Buy...Need help!
    Last Post: 07-21-2008, 03:52 PM
