586,213 active members*
3,784 visitors online*
    Mar 2007
    215
    135 Degree Split Point Drills
    Hey Folks,
    was looking at ordering these 135 degree split point parabolic drills manufactured by Titex. Was wondering if these need to be spot drilled first and if so what angle spot drill. I can't seem to find any spot drills over 120 degrees.
    CM
    Feb 2011
    I assume your talking about carbide drills. Generally the bigger size carbide drills - no - don't bother spot drilling. if your talking about the likes of drills from 1.5mm down, i would spot drill yea. WNT have an 142 degree carbide spot drill in their catalog. www.wnt.com. Well thats my opinion anyway.
    Mar 2007
    215
    Thanks Marcutous. The smallest one I'm using is a 1/16" (about 1.59mm.) I am expecting the drills today or tomorrow, I'll let you know how it goes.
    Nov 2008
    20
    I use Titex drills every day and do not spot any unless under 1/16
    Feb 2006
    338
    If you have any issues or concerns with location or drift on longer drills, try a 2D deep pilot hole with a carbide screw machine length drill of the same point angle.
    Again this would only be needed with small diameter drills and/or jobber and longer length drills.
  1. Carbide Drills 3x 5x 8x Diameter Drills
    By CDTooling in forum News Announcements
    Last Post: 09-10-2010, 02:37 PM
  2. can't split big model
    By 15mgtar in forum Rhino 3D
    Last Post: 03-20-2010, 04:21 PM
  3. Split/NCS
    By gplush in forum Uncategorised CAM Discussion
    Last Post: 11-05-2009, 11:56 PM
  4. There's Drills, Mills and Mill/Drills so what's the....
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2009, 03:04 PM
  5. Replies: 3
    Last Post: 06-30-2008, 01:30 AM
