586,114 active members*
3,376 visitors online*
    Nov 2006
    251
    Hawke 150 programing
    Hi guys,Gotta run a small program with a bar puller on my cincinatti hawke 150 with a2100 control,could anyone tell me what the command is to loop the program 20 times I have looked through the book but it does'nt say exactly where to start.We dont normally run lots of parts and just use barstop and restart,but it would be nice to let it run on its own for multiple parts.A small program example would be much appreciated to get her started thanks in advance.
    Oct 2008
    123
    Hawk 150 programming
    Hello Greg
    it's been a long while since i programmed but try this
    at the start of the program put in a 'count'
    ie :g0t1m6
    [#count]=0
    [here]
    program
    at the end of the programme
    [#count]=[#count]+1
    (IF[#count]<20 GOTO [here])
    M30
    you'll find it in chapter 10 of the programming manual.
    regards
    mallardfizz
    Nov 2006
    251
    Thanks for that Dick,I will give that a go in dry run (maybe) or in a small program with no stock in the chuck.regards Greg.
    Nov 2006
    251
    Tried that program loop Dick it worked pretty much spot on bar a few nitchy bits,I went through chapter 10 and really cound'nt find to much there,my manual may be a bit different.Thanks once again Greg.
  1. Hawke 150 spindel problems
    By greg b in forum Cincinnati CNC
    Last Post: 11-19-2011, 08:10 AM
  2. On programing this
    By harm in forum CNC Machining Centers
    Last Post: 11-06-2011, 11:40 PM
  3. cincinatti hawke 150 spindel drive
    Last Post: 02-11-2011, 01:39 AM
  4. NEED SOME PROGRAMING HELP $$$$
    By lildave26 in forum Employment Opportunity
    Last Post: 01-06-2011, 05:05 PM
  5. ? on programing
    By markjb in forum Fadal
    Last Post: 03-16-2009, 11:09 AM
