586,071 active members*
3,900 visitors online*
Results 1 to 8 of 8
    Jun 2007
    3757
    Question How do you add external control pots on Mach3
    I am sure it can be done.
    Has anyone made external speed and feed over-ride controls using potentiometers?
    24221
    Not sure if there is anything out there already, but it may be better to look at the common commercial O/R method of using a Binary switch, 4 bits give you 16 steps/switch.
    Al.
    Albert E.
    Jun 2007
    3757
    I will design a method. Just thought there maybe a way it is typically done already. No point reinventing the wheel, so to speak.
    Needs to be at least 8 bits to be fine enough to be practical.
    I suppose you could up/down button, but that is not nice, and the latency would make it awful to use.
    An 8 bit switch if it must be digital.
    Can always make an 8 bit output A/D converter, but it will need gray code output so every step is different. Then how do you feed that into Mach3?
    That is a lot of bits for 2 pots, using a parallel port.
    USB, maybe, but will latency be an issue?
    I suppose an MPG type input could be made to work.
    The easiest way is probably with a Pokeys.
    PoLabs - Affordable PC USB oscilloscopes, logic analyzers and USB interfaces
    They have analog inputs and apparently work well. Never used one, though.
    24221
    I see there is a plugin for Contec PIO boards, I am surprised that by now no one has developed a PC Based PLC for Mach using these cards.
    All the preferable operator hard wired functions such as feed hold and feed overide, spindle O/R etc could be done digitally this way without messing with analogue inputs etc.
    A resolution of 255 is hardly necessary for most overides.
    Al.
    Albert E.
    Jun 2007
    3757
    The PoLabs idea looks good with the plugin, and 10 bit is more than adequate!
    Any other ideas out there? Now we are getting somewhere.
    Aug 2006
    89
  1. Mach3 and external PCI parallel card?
    By Cooper in forum Mach Mill
    Last Post: 01-20-2013, 01:30 PM
  2. Replies: 12
    Last Post: 09-17-2011, 05:25 AM
  3. Control Mach3 with external VB.NET program
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 12-30-2008, 04:46 PM
  4. Mach3 External Estop Reset
    By bcromwell in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2006, 05:16 AM
  5. Mach3 External Estop Requested
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2005, 04:56 PM
