586,055 active members*
4,291 visitors online*
Results 1 to 7 of 7
    Jan 2007
    103
    AeroTech-dust free nesting
    has anyone used the AeroTech system for dust free nesting?
    Made by FS Tool / FS Cruing?
    I have heard some good reviews and I'm looking for more info.
    May 2006
    42
    We tried one, when nesting you will typically use a compression bit along with vaccum hold down. Both of these work against the vortex created. Oh by the way hope your dust collection is better than average becuase what ever dust it does pull up is on the move in the direction of least resistance. We did not buy it.
    Dec 2011
    Aero Tech
    We did get one and it works great, there is no dust left. However, we do a lot of cutting in melamine drawers, 5/8, and the dwr bottom is grooved .25 into the dwr side, .375 up from the bottom. Because we onion skin the smaller dwr pieces, on the 2nd pass, 'cause of the long upcut flute, it tends to rip of 1.5" - 2" pieces on the end. Looking to see if we can get it with a smaller upcut on the bottom, if not, we'll have to quit using it. But again, for straight perimeter cuts, GREAT.
    Jan 2007
    103
    they make aerotech bits in any upcut length.
    i have found their bits to work the best out of what i've tried.
    call FS Tool and ask for Frank. he will give you the best option for what you need.
    How thick is you're onion skin? We use .01", and I can't see how the part could get damaged on the onion skin pass.
    Also, how fast can you cut with the Aerotech?
    Jan 2007
    103
    aerotech with the "speedmaster" bit is ridiculously fast. and clean cutting, and longest running bit. IF your machine and setup can handle it.
    even the speedmaster without the aerotech is the fastest, longest life tool we've used.
    Dec 2011
    we go .01", the tool sales guy set it to run at 18,000 rpm , and 14,000 mm/min. the reason for the breakout is there is only .375" melamine left, and when it enters /exits the 2nd time the vacumn or something rips it out. tried with different shorter upcuts and no problems
  1. Powerful Automatic Nesting software for FREE!
    By glenn@mynesting in forum News Announcements
    Last Post: 04-24-2011, 07:26 AM
  2. Dust/Chip Control...CNC Dust Enclosures
    By Too_Many_Tools in forum DIY CNC Router Table Machines
    Last Post: 07-29-2006, 07:44 PM
  3. 2D On-Line nesting - Nesting on-demand !
    By mijo in forum News Announcements
    Last Post: 03-21-2006, 04:42 PM
  4. aerotech XI program
    By davidponte in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2005, 05:56 AM
  5. How do you keep your linears free of dust?
    By johntbyrne in forum DIY CNC Router Table Machines
    Last Post: 06-20-2004, 06:43 AM
