603,942 active members*
2,685 visitors online*
Results 1 to 6 of 6
    Nov 2009
    5
    RFQ - router/mill work on HDPE sheet
    I need a HDPE sheet (2" thick 20" wide 20" long) cut with a simple design. Please see the PDF below, this will be a one off until i perfect the design then i will need around 5 of them.
    Thank you
    Mike
    Attached Files Attached Files
    Feb 2008
    Mike,
    Are you supplying the material and your location (for shipping cost).
    Laz
    Feb 2006
    196
    Mike,
    Do you have a specific HDPE in mind? Do the (4) deep corners need to be sharp?
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    depryor@davidwolfedesign.com
    Nov 2009
    5
    Quote Originally Posted by dpryor View Post
    Mike,
    I am sorry to everyone that has read the post i am very new to this and i missed a few details, but i am learning from these mistakes.
    There is only 1 critical dimension to my design and that is the depth on the second cutout (the one with the 4 circles) that needs to be as close to a .25" as possible aside from that nothing else is critical all corners can be rounded.
    as for the HDPE it really just a cost issue that pushed me to use HDPE, the original plan was to use delron or Teflon but at close to 900$ for that size of a plate it WAY outside my price range.
    If anyone knows of a good material that i can use for this project i will gladly switch i am hoping to get these items down for about 50 to 100$ a unit that includes material (not including shipping)
    The qualities i am looking for in the material are:
    can hold back water (the part will be filled with just simple water)
    can handle mild grinding ( the part will be used to grind down a stone plate to a connect size and i need it to hold out for about 4 or 5 stones tiles before i need to replace the part)
    i am sorry if i made it out to be a huge project i can see anyone with a hobby level CNC router being able to run this part for me.
    Thank you
    Mike
    Nov 2009
    5
    Project is on Hold for redesign of part i did not realize that HDPE can be so expensive.
    Thanks for all the help
    Mike
    Jan 2008
    449
    Quote Originally Posted by Egonsith View Post
    Mike
    If you hunt around on McMaster-Carr HDPE appears to me the cheapest plastic type material in that size at around $200, even PVC is more expensive. What about a hardwood and sealing it? You could probably shop around and beat that McMaster price by 25% or so.
  1. Replies: 6
    Last Post: 10-04-2011, 10:54 PM
  2. HDPE for router build?
    By kiwichris in forum DIY CNC Router Table Machines
    Last Post: 06-28-2011, 11:42 AM
  3. DIY router parts: HDPE vs cutting board
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 09-14-2010, 08:38 AM
  4. Modular CNC HDPE Low Cost CNC Router
    By Modular CNC in forum News Announcements
    Last Post: 08-17-2009, 06:10 AM
  5. Will this Router / Mill work?
    By upside in forum DIY CNC Router Table Machines
    Last Post: 03-17-2009, 05:40 AM
