586,103 active members*
3,737 visitors online*
Results 1 to 8 of 8
    Yasnac MX1 Options
    How do you turn on the 4th Axis Option?
    Thanks for your help!
    Kent
    Feb 2009
    6028
    4th axis is WAY more than just an option parameter. You need the drive, cables, 4th axis, parameter set up to control the 4th axis properly. Don't ever remember having to turn on an option parameter installing a 4th.
    4th Axis
    This is a 1985 Mori Seiki MV80 VMC w/ Yasnac MX1. It has the driver, cables, and 20" Koma Rotary Table. But the Parameters are not there. When you go to the recommended address, no bits are shown. I suspect someone took the rotary table off at some time and just didn't re-install it properly.
    Feb 2009
    6028
    I'll see what I have when I get home.
    Jul 2005
    380
    Most likely, everything is still in the CNC, but the additional axis address is switched off. When I bought my P&W (read Hamai) TriMac VMC it had a 15" Tsdokoma table that they wanted to keep. So when I got the machine, I had to go into IPL mode and tell it that it was a 3 axis VMC and not a 4 axis. Once I did that, the additional drivers and boards went into a "standby mode" and the machine operated normally. That was 10 years ago, never had a problem.
    May 2008
    84
    Re: 4th Axis
    Do you have the parameters you can send me? We are trying to set up a 4th axis.
    Quote Originally Posted by kgimachinetool View Post
    Apr 2013
    12
    Re: Yasnac MX1 Options
    Kent
    Do you still need this information?
    Quote Originally Posted by rodrigomex View Post
    I need information, please
  1. Replies: 4
    Last Post: 02-15-2012, 04:52 PM
  2. Yasnac mx1 vs. mx5
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 06-10-2009, 05:32 AM
  3. Yasnac help
    By cncwhiz in forum Uncategorised MetalWorking Machines
    Last Post: 03-26-2009, 12:48 AM
  4. Yasnac LX3
    By inthedark in forum MetalWork Discussion
    Last Post: 08-07-2008, 11:03 AM
  5. yasnac J 100 M
    By Furlan in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-17-2007, 04:55 PM
