588,130 active members*
4,880 visitors online*
    Feb 2009
    8
    Mazak Mazatrol ?
    I am looking at a new Mazak with Mazatrol. My question is we program only using G & M codes. Is the Mazatrol easy to work with using G & M code programing.
    Kevin
    Apr 2006
    3206
    Mazatrol is really pretty simple, and the vast majority of lathe jobs can be programmed right at the machine.
    Personally I prefer the comfort of programming at my desk, using a cad/cam package, then loading the post processed G-code into the control. With the Mazak, once you get accustomed to the way the Mazak thinks and learn how to lie to it, it's pretty quick programming.
    You can also cut & paste segments from other programs into the current one to say a lot of time. The graphic ability to proof your toolpaths is also pretty good.
    Have never run the milling equivalent, but I'm sure someone around here can chime in on that side.
    Btw, you can load in G & M code programs. .... But you may end up wondering why, when you can take a print to the machine, and just punch it in.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Mazak QT 15 with Mazatrol CAM T-2
    By cncren in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-23-2012, 01:06 PM
  3. Mazak Mazatrol M2
    By sve0019 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-30-2010, 08:40 AM
  4. Mazak, Mazatrol T1
    By valvulin in forum Spanish
    Last Post: 10-10-2008, 06:17 PM
  5. Mazak H15 with Mazatrol M2
    By Steve_rb in forum DNC Problems and Solutions
    Last Post: 03-19-2004, 01:27 PM
