603,365 active members*
2,611 visitors online*
    Apr 2011
    Roland Picza 3D Scanner
    Hi All,
    I just bought a user Roland Picza 3D Scanner Digitizer. I know this is a strech regarding 3D milling but I am using it to scan objects and then milling them so hope you don't mind. Does anyone have access to a manual by any chance? Also the Picza has a serial printer 25 pin. Can I use a 25-pin serial to-9 cable then to as USB cable? Does anyone have one of these out there?
    Many Thanks,
    Tony
    PhilO Guest
    I have the manual in PDF. I am new to this forum. How can I send it to you?
    The cable arrangement, 25-pin serial to-9 cable the ( pin to USB, will work. Try a Google for that.
    Phil
  1. Roland Modela MDX-3/Picza PIX-3
    By Graeme G in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 04-05-2020, 03:32 PM
  2. roland MDX-40 with 3d scanner and 4th axis
    By kenli854 in forum Want To Buy...Need help!
    Last Post: 07-18-2010, 04:01 PM
  3. Roland Scanner and DIY CNC Router
    By theboneman in forum DIY CNC Router Table Machines
    Last Post: 07-06-2008, 05:13 AM
  4. RFQ 3d scanner
    By ssrmr2 in forum Employment Opportunity
    Last Post: 06-03-2008, 08:45 PM
  5. Has anyone used a Roland 3D scanner
    By buscht in forum Digitizing and Laser Digitizing
    Last Post: 04-10-2004, 08:57 PM
