586,089 active members*
3,819 visitors online*
    Aug 2011
    I-Beam Bridge
    A friend and I are building an I-beam bridge that needs to be 14ft wide and span 25ft. He was thinking of using 4 W14x38 beams. How would you go about calculating the weight that the bridge could support? This is a bridge he's using to get trucks across so it has to be fairly tough.
    Jan 2010
    485
    Here's a link to how to calculate loads. Good information all in one place; http://www.engineersedge.com/
    May 2009
    71
    What are the dimensions of that beam? What is the tensile strength of the steel being used? Are there going to be any supports (piling in middle, gussets). What do you want the factof of safety to be (typically 2.5 or higher for bridges). What is the footing going to be (concrete?), thickness, etc. What about the material under the concrete? There are a lot of variables need to be specified. What I would do is build the bridge based on the load needed, then use a factor of safety of 3 (build 3 times stronger than what would barely hold up).
  1. Replies: 0
    Last Post: 03-09-2011, 04:39 AM
  2. Beam strength for miniature railway bridge
    By Web.eng in forum Mechanical Calculations/Engineering Design
    Last Post: 01-22-2010, 01:48 AM
  3. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  4. Half bridge or Full bridge
    By bunalmis in forum CNC Machine Related Electronics
    Last Post: 04-13-2008, 08:11 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
