Hi Jess,
Thanks for the feedback, much appreciated. Interesting what you say about the CES 626 looking to be a good machine. Like you say I expect the cost is a big issue.
I have basically ruled out the RF40 because of the apparent consensus view that is is nearly impossible to convert to cnc (tough if there are any descenting voices I would love to hear them, because you seem to get a lot of table travel and a weighty machine (300kgs) for the price).
Looking at the other two, I have drawn up a comparison table that I thought others going through this kind of process may find useful.
Model: -- SIEG X3 Super -- Sxminster CES-626-A2
Base Size: 340 x 430 mm -- 630 x 460mm
Lateral Table Movement: 145mm -- 150mm
Longitudinal Table Movement: 400mm -- 370mm
Nett Weight: 165kg -- 260kg
Nose of Spindle to Table (Max): 380mm -- 0-345mm
Power: 1,000W -- 750W, 1ph
Rating: Trade -- Industrial
Spindle Speed: 100-1,750rpm -- 200-2,250 rpm
Spindle Taper: 3MT -- ISO 30
Table Size: 550 x 160mm -- 600 x 152mm
Table Travel: 400 x 145mm -- 370 x 150mm
Coolant pump no -- yes
Price £1,300 -- 2,629.50 with stand
X3with stand £1491.50
So that is quite a big price difference, for something that on paper looks quite similar. I guess the main difference is in the build quality and general sturdiness? My current thinking is to opt for the X3, have more to spend on tooling, clamps, etc. and save a bit of money too.
Bongodrummer - www.FloweringElbow.org
