586,909 active members*
3,237 visitors online*
    Nov 2008
    4
    Problem with threading cycles
    We have an old Mori ZL-250 that we typically use just for simple parts that are turned, drilled, bored, etc. We have to do a small run of a part that is OD threaded and when we try to use any of the threading cycles we get a 490 alarm which is related to the spindle. This happens in G92, G76 and G32. All other G commands work fine. Any ideas about where to look? Thanks in advnace for any help you can provide.
    Jul 2010
    369
    What type of Control does it have?
    http://www.cncalarms.com/
    Nov 2008
    4
    It's a fanuc 18i. We think it might be the spindle speed sensor causing the problem.
    Jul 2010
    369
    It may be an easy fix if its the spindle encoder.
    Then it may not be.....
    Hope Not!
    Check all the connections, unplug/plug back in after cleaning.
    Make sure the belt is not skipping teeth on the spindle splines or the encoder pulley, etc.....
    Also do the rpm's match what you programmed on the screen?
    Let me know what yall find out.
    http://www.cnczone.com/forums/fanuc/...lem_-_rpm.html
  1. G78 Threading Problem
    By bigmantate in forum European Club House
    Last Post: 09-07-2010, 07:10 AM
  2. G76 Threading problem
    By bmlw in forum Fanuc
    Last Post: 02-26-2010, 11:42 AM
  3. threading problem
    By girishnadkarni in forum Fanuc
    Last Post: 08-29-2008, 11:22 PM
  4. Ultimax II Canned Drill Cycles Problem
    By badboy in forum HURCO
    Last Post: 06-11-2008, 06:40 AM
  5. canned cycles problem
    By joachim in forum Fanuc
    Last Post: 04-01-2008, 06:01 AM
