603,352 active members*
3,486 visitors online*
Results 1 to 7 of 7
    May 2008
    14
    threading problem
    hello ppl
    we are into machining of duplex and super duplex stainless steel machining on turning centers and have threading operation on major components
    im finding lot of problem to keep up the life of threading insert with less cycle time
    threading spec 8un class 2a thread
    dia 53.75 mm for a length of 40mm
    75mm do
    79mm do
    im not able to go above a depth of cut of 0.1mm diametrically
    controller fanuc oitc
    can any body suggest me a good solution for this
    May 2007
    1003
    You may not have given us enough information to be of much help. What RPM are you running? What insert are you using? Can you give us the threading cycle you are using? I don't mean G76 2-block call either. What values are in the cycle?
    Right off the top I'd like to know why you can't take more than .1mm diametrically? Never heard of such a thing. That amount is ok for the last pass, but is way too shallow for the first pass. No wonder you can't get any tool life. I wouldn't expect any unless you were cutting warm butter.
    May 2008
    14
    rpm of 380
    G21 threading cycle
    carmex insert 16er 8un
    sandvik R166.OG-16UNO-080-4125
    if at all i increse the depth of cut the insert blows off
    i tried it with g76 cycle but the flank wears out quickly
    and the is no provision for alternate flank infeed method in this control
    any soln for this
    May 2007
    1003
    Looks like the 4125 should be running around 350 sfm. I assume you are using the MXC Carmex grade. That should run at least that fast also. That means you should be running around S635.
    I am not familar with G21 threading cycle, so I can't help you there unless you want to post a threading cycle, and explain what each word represents so I can figure it out. Well...I think I could figure out what the X, Z, & F (or E) stand for. I've been fighting threads for a long time.
    Can I assume you are running a 2-1/8 8UN thread? What does the 75mm do and 79mm do refer to in your first post? Size of the local cow pucky? Sorry, little sick humor.
    Can you control compound infeed? Which G76 thread cycle does your control use? I am very familiar with those. Care to post what you have tried with the G76 cycle?
    One thing to remember is that some grades of inserts won't run very well if you go too far below their suggested range. You are running around 210 sfm for the first cuts. SFM too low, and the material sticks to the insert. Next cut can cause a chunk of the insert to chip off. Also the material is probably workhardening at those DOCs.
    Mar 2008
    638
    The other guys know much more about the threading cycles so I'll just ask a tool set up question: Are you sure you have the right shim for your laydown tool at that diameter? At that size, it's probably not the one that was originally supplied.
    May 2008
    14
    the material which im machining is CD3MWCuN DUPLEX STAINLESS STEEL
    which contains ni, Cr, molybdenum which makes the material sticky and hard for machining
    i have tried using g76 flank infeed method which does not work
    nw we use G21 X53.75 Z-40 R0 F3.175
    X53.65
    X53.55
    X53.45
    .... AND SO ON TILL THE THE THREAD DEPTH IS ACHIEVED
    X IS THE DIA FOR THREAD PASS
    Z IS THE LENGTH
    R IS USED FOR TAPER THREADING
    F IS THE PITCH OF THREAD
    THREADING SPEC 2 1/8" 8UN
    2 5/8" 8UN
    3 1/8" 8UN
    THE SHIM IM USING IS AS PER THE HELIX ANGLE
    NW TEL ME IS THR ANY WAY OUT
    May 2007
    1003
    Being in the USA I am not familar with that material, but have machined materials of similar makeup. Your G21 is like my G92. It doesn't use compound infeed. A zero degree infeed creates a tough chip. I haven't used this cycle since Hector was a pup.
    Does your starting point clear the diameter so that the threading tool won't drag on the material on the return move? I ask because you said the insert keeps breaking.
    Try
    G97S600M3
    T0101
    G0X55.Z13.M8
    G76P000129Q008R.076
    G76X50.11Z-40.P364Q045F3.175
    OR
    G76X50.11Z-40.K3.64D450F3.175A50.
    depending on control.
    I don't program in metric, so please make allowances if I am off on some figures. I think you should be taking a minimum of .015 thousandths per side on the first pass. I tried to set it up to take a minimum cut of .003 thousandths per side and the same depth for the last pass. This is to keep the material from work hardening.
    I normally use 29 or 55 deg. for my compound infeed with the 2-block G76 and 50 deg. with the 1-block G76 call. I use 60 deg. if slowing RPM doesn't eliminate chatter. It has the least amount of tool pressure.
    If the insert gives problems on the first pass, lie to the control by making the P or K larger. This will give you a lighter cut on the first pass without increasing the number of cuts significantly. If you lower the Q450 or D450 by a couple thousandths, it will result in a lot more passes.
    EDIT: This should be a good starting point, but realize that you may have to modify a bit. Might be able to run another 50-100 RPM faster. May need to take a lighter finishing pass. Could be you need to make a couple spring passes to hold pitch (hard on insert, and doubtful with this coarse thread). May need to try different compound infeeds. May have to give it a greater thread height, etc.
  1. Okuma LC-20 Threading problem
    By Gunner in forum DNC Problems and Solutions
    Last Post: 12-14-2011, 05:11 AM
  2. MDF threading
    By MrWild in forum Commercial CNC Wood Routers
    Last Post: 01-01-2010, 05:17 PM
  3. CNC threading problem
    By 3bmachine in forum MetalWork Discussion
    Last Post: 05-25-2008, 11:02 PM
  4. Threading problem on Mori seiki zl-15smc
    By DryRun in forum G-Code Programing
    Last Post: 09-19-2007, 05:57 PM
  5. threading with live center problem
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 10-31-2005, 03:14 AM
