603,855 active members*
4,044 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Adding text/color after anodizing
Results 1 to 14 of 14
    Aug 2011
    I see lot of aluminium products being anozided black and then there's some text like brand or product name on white text. How do you archieve that? First anozide black and then print the text/other colors somehow?
    Also, to get most matte like finish, should I use emery cloth before the anoziding process?
    Apr 2010
    486
    Feb 2009
    6028
    First, a lot of logos and such are silk screened over the anodize. The other option is engraving after plating, then use engravers paint to get what ever color you want.
    As far as the most mat finish, bead blasting will net the most uniform mat finish.
    Aug 2011
    Quote Originally Posted by underthetire View Post
    Thanks for the reply!
    Does the silk screened print wear off easily?
    I'm looking to get this kind of finish, so I guess bead blasting before anoziding is the way to go:
    Can good bead blasting be done at home for small parts (to save some money) or is it better to give some shop to do it?
    Feb 2009
    6028
    Some silk screening does wear off fairly easy, Ive also seen some that last a while. You can get DIY kits from places like Ebay to try it out. Yes you can do bead blasting at home, you will need a large air compressor and a blasting cabinet. Harbor freight has cheap blasting cabinets, but the air compressor is what will make or break the operation.
    Apr 2010
    486
    You need to be friends with the mechs at your local airport. They always have a nice big bead blast cabinet, and a huge air compressor.
    Tom
    Aug 2011
    I would need something that doesn't wear off the second it's moved against another aluminium plate. It will not give very professional impression if the text goes off too easily. So maybe silk screen printing isn't option for me?
    Do you agree that the finish on that picture can't be archieved without some sort of blasting?
    Feb 2009
    6028
    Hard to tell, but looks bead blasted, then maybe hard anodized. Hard anodize is typically more of a matte black. And any standard printing will rub off against another piece of aluminum. Engraving would be your only option to get white lettering that won't wear off.
    Aug 2011
    Ok. Does the silk printing wear off in rain for example (just trying to figure out how easy it comes off, I guess it lasts better than spray paint at least )?
    I looked up some images from google and it looks like bead blasted. I've seen that part in real life and it looks like the surface is made from tiny dots rather than long lines you see on the surface after machining. And in the holes etc it looks more like lines etc so that could mean that the bead blast haven't reached those areas as well as the main surfaces.
    Aug 2011
    Here's another pic that shows the black matte look I'm after: http://www.rankinarms.com/guns/files/unique-002.jpg
    Aug 2011
    I've been reading mixed opinions about the bead blasting. Some people say sand blasting for aluminium is bad if you anodize it and that glass blasting is better. The nsome people say that glass blasting will make more glossy like surface rather than matte...
    Feb 2009
    6028
    I prefer the bead blast. Easy enough to have one of each done and plated to see what you like better.
    Aug 2011
    Here's better image of the surface I'm after (the grey part, mine will be black): http://homepage.mac.com/xeonitedog/Kimber04.JPG
    Aug 2011
    How about laser printing? What is plusses and minuses with laser and silk printing for aluminium (if only white print color is needed)?
  1. Adding text to a tire sidewall
    By MPMW in forum Solidworks
    Last Post: 07-17-2009, 04:11 AM
  2. How do I make different color text?
    By chippah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-08-2008, 06:17 PM
  3. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  4. anodizing
    By pyroracing85 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:22 AM
  5. adding anodizing tolerances on drawings
    By groovemixer in forum Mechanical Calculations/Engineering Design
    Last Post: 03-21-2007, 10:11 PM
