588,130 active members*
5,775 visitors online*
Page 1 of 40 12311
Results 1 to 20 of 789
    May 2006
    309
    Any experiences with CNC 6040 ROUTER?
    I see this router is sold on ebay for about 1300 usd. Is this a good deal for a router like this, and is the quality ok?
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    Dec 2007
    362
    I bought one of these about 3 weeks ago. Unused so far as I'm house sitting and have no where I can set it up. Once I get a place of my own and get it installed, I'll let you know how it goes.
    Construction seems solid and it was well packed and arrived without damage. Not sure about the quality of the stepper drivers but I've got a Gecko G540 in case it's needed.
    Needless to say there's no documentation to speak off
    If you want any info that doesn'y involve me starting it, let me know.
    Regards
    Geoff
    Oct 2007
    13
    Anymore comments on these machines? Price looks ok.
    Nov 2007
    16
    I bought one, and it works!
    after reading about other people with the 6040, and the 3040 (basically the same, but smaller),
    the other users have had problems with the control-box, and the VFD's manual, so I decided to ask the seller if he would sell the machine without the control-box and VFD, And he did.
    I ordered a Gecko G540 , and I already had a decent Danfoss VFD with a understandable manual.
    The machine arrived in two boxes, one with the table, and one with the gantry, spindle, steppers and wires etc.
    Now everything is working perfectly, and setup went smooth with very few issues.
    There are however a few points that is bad with the machine:
    no home/limit-switches
    the table is not perfectly flat over the whole area
    the cable-chain has not got space for all your cables and hoses (if you go for a water cooled spindle, like me)
    Nov 2008
    17
    Alekoy, may I ask you, who was the seller you bought your machine from?
    I asked several of them and none is willing to sell it without controller / spindle.
    Thanks!
    Dec 2007
    2134
    Quote Originally Posted by Foogl View Post
    Thanks!
    Do you already have a VFD/spindle? If not, I'd get it with them as it would only be an incremental cost when buying the machine, and while they aren't top of the line, they are cheap and work. These machines for the price are generally very good, and apart from the mandatory replacement of the controller with a G540, only need some minor tweaking and adjustments really. performance of the one I have is very nice. Funnily enough the alu table is better and more robust than the one on my larger Jinan JCut 6090. Go figure!
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Nov 2008
    17
    Thanks Ian. What I'm trying to do is to get 6040 with 1.5kW spindle and complete it with my G540. Unfortunately, sets on ebay has 0.8kW spindles + el cheapo controllers and so far there was nobody willing / able to deliver me different configuration. So again, can you tell me, who did you buy your machine from?
    Dec 2007
    2134
    I got mine from "lovehappyshopping", but these guys -
    amonstar | eBay
    - appear to be about the cheapest currently. Almost all of them also sell the 1.5kw spindle/vfd sets, so you could ask to upgrade the one on the machine, but it's quite possible that these generally are turnkey sales so I wouldn't be surprised if they wouldn't be able to. Failing that, you could buy a 1.5kw set, and just swap them over yourself, but having said that, the 0.8kw is a surprisingly capable and powerful spindle, and may well do you fine for most work. And given that the cost component of the 0.8kw spindle and vfd would be a very small part of the cost of the overall machine, I would think it handy to just have around for when you build 2nd, 3rd, 4th, etc, machine! Shame the controller that comes supplied isn't of any use though!
    One thing I forgot though, is one of the first things you'll need to make if you buy the 1.5kw set as well, is an 80mm spindle mount! That was actually what I did myself!
    For the money, these are awesome machines, and seeing as you've already got a G540, you're home and hosed!
    cheers,
    Ian
    Nov 2007
    16
    The seller I bought from was Tool-zoom, I contacted them on ebay, but the buying itself was outside ebay, and the payment was done on paypal.
    Arrived in Norway in less than a week, shipped by DHL.
    Now that I have used the machine a little, I would say that the little 0,8kw spindle is sufficient, I've milled alu, MDF and 3mm sheet metal and the spindle has done its work without any hesitation. BUT if the 1,5kw spindle does not cost a whole lot extra, I probably would buy that (bigger is almost always better)
    Dec 2007
    2134
    I've got the 0.8kw, 1.5kw, and 2.2kw spindles, and as i'm very mindful of the cost of running these things for extended periods, I personally find the 1.5kw to be the sweet spot for power usage, grunt, and performance.
    The 0.8kw is more than adequate for most use, and is especially suited for mundane and repetitive stuff that's fairly easily machined, while the 1.5kw is really great for plowing through lots of aluminium machining. The 2.2kw I haven't found really offers that much of a performance boost over the 1.5kw for my needs currently, so all general stuff is done with the 0.8kw, and heavy machining with the 1.5kw.
    I am planning a cnc machine next year or so, specifically for machining aluminium with flood coolant, and I'm setting aside the 2.2kw for that purpose as it will be fairly hard work, but the grunt would just be wasted on lighter stuff IMHO. Here in OZ our utility bills are going through the roof, so running costs are more and more a real concern.
    cheers,
    Ian
    Nov 2008
    17
    Quote Originally Posted by aarggh View Post
    Sooo, my two boxes with 6040 arrived. You hooked me up Ian!
    Looks like no damage on the way. Packaging was absolutely fantastic, bubble wrap, PU foam, foil ... would take me a week to pack it like that.
    Frame looks nice and sturdy (and heavy), spindle looks really good, movements all nice and smooth, servos are fine (270oz), VFD is acceptable. But man! Wires and controller are absolute crap (expected). No shielding, no grounding, nothing. I didn't even have balls to start that blue box up. I'm going to visit McMaster-Carr tomorrow (it is absolute joy to live 5 miles from this wonder-store) for new cables and I will hook it up with my new G540 right a way. Cannot wait.
    Thanks for the good tip!
    Dec 2007
    2134
    Great! They really are good value, you'll probably find the table will be very slightly out over some of it, but no big deal to shim or adjust that. I didn't find mine to out enough to worry me for what I was doing with it. Good idea to not touch the supplied controller, otherwise you might reasonably think it's worth "having a look at", after all, just how bad could it be? And before you know it, you've lost a week and it still doesn't work!
    The g540's are a real treat, they have a rock solid reputation for a good reason, they really are that good!
    I'd recommend checking over the cabling though, and make sure all the connectors are solid, and start mapping out the A-/A+ and B-/B+ from the controller (assuming it's wired right, if it's not, doesn't matter as you'll soon work it out) to make it easier for the G540 hookup.
    cheers,
    Ian
    Dec 2007
    362
    I finally been able to get mine set up, at least as far as the controller would let me - dead X axis.
    Rather than try to chase down the seller to get a replacement, I'm just going to build a new box with a G540. Got the power supply, connectors, switches etc yesterday and should have the cable tomorrow.
    I did have to take the hardware apart as it was out of alignment, probably due to a couple of weeks in the back of the van. No binding on any axis but the ballscrews could use some grease - if there were grease nipples installed.
    Once I get movement under G540 control, then I'll tackle the VFD.
    Has anyone worked out the best place to fit limit/home switches?
    Regards
    Geoff
    Dec 2007
    2134
    Quote Originally Posted by tumutbound View Post
    I haven't found a home/limit switch setup I've been happy with so can't help you there sorry, but with the grease, if it was anything like it was on mine, it's a horrible thick gunky mess. I cleaned it all off with kero and used fresh good quality (lithium based from memory?) grease, and it was smooth and quiet. My other machine had the same sort of grease and it actually seems to go hard and gum up the balls after time.
    Have you looked at the mach3 screenset for the zero-axis from ger21? I'll be aiming for that myself.
    cheers,
    Ian
    cheers,
    Ian
    Dec 2007
    362
    Problem with mine was (is) no grease!. There's nothing evident on the ballscrew and I can't tell if there is any in the ballnut itself. A lack of grease nipples and no way to install any, doesn't help.
    I'll be wiring up the control box as per the diagram from Homann Design. I got the various parts I needed from them (except the G540 which I already had). I especially like the 9 pin stepper breakout boards with a built in variable resistor
    I'll look up ger21's zero-screen set to see what it is Still getting to grips with Mach 3.
    Regards
    Geoff
    May 2006
    309
    Do you need nipples for grease? Wouldn´t it be sufficient to smear the lead screws and the grease will then get to the balls when they run over it?
    Dec 2007
    2134
    Quote Originally Posted by jaru-eri View Post
    For ballnuts grease nipples are definately the better option for smoother and longer lasting lubrication, as it's far better to force the grease under pressure outwards from the nipple, than to have a thin smear covering only part of the ball races, likely never reaching the inner parts, and also likely introducing a higher degree of contaminants in the process.
    cheers,
    Ian
    Nov 2008
    17
    Can you put nipples on 6040 without modifications or one have to drill?
    Sep 2011
    4
    CNC 3040Z
    A I wanted to play with Photocarve,I bought a 3040Z (small version of 6040) as my Syil is too slow and the head to heavy for the rapid up and down moves. I ordered it from lovehappyshopping. Arrived with the vertical axis shaft end 1/4" and 3/8" top plate badly bent, before it was packaged as no significant damage to packaging. Replacement ballnut and screw arrived quickly. After such an impact, I dismantled the whole machine to check for damage. There was none and the machine is a wonderfully simple but very robust bit of kit. It would be a simple job to use the mill the make a duplicate or larger model of itself. Having read the posts about the control box, I wondered how it was going to perform. However it was pretty ok, fairly accurate on positioning checks. Dont forget the cheeky way to get power to the opto isolated parallel port skt. It needs 5v stolen from the computer's USB. Saucy sods.
    The Y axis ballnut has a grease nipple screwed in, the others have screwed port, but no nipple and would need to be dismantled to get at the nipple if one is fitted.
    Jan 2012
    hey guys,
    I've been looking at getting one of these machines as well, I hope to be using it for building some automotive models like these:
    Uploaded with ImageShack.us
    What do you guys reckon, obviously the depth would need to be modified (the largest I can find is 120mm which might even work) but would a machine like the 6090 be able to pull it off? I'll only be milling foam or mdf.
Page 1 of 40 12311
  1. Experience with carving-cnc.com 6040 router
    By Helloagain in forum Chinese Machines
    Last Post: 05-29-2016, 09:12 AM
  2. Chinese CNC Router (CNCDIY 6040 )
    By Domenicxx in forum Australia, New Zealand Club House
    Last Post: 10-23-2012, 09:08 AM
  3. New 6040 router issues
    By Shadow3081 in forum Chinese Machines
    Last Post: 10-09-2012, 04:42 AM
  4. Help with the CNC 6040 router engraver
    By pommymark in forum Australia, New Zealand Club House
    Last Post: 12-08-2011, 11:56 AM
  5. Exitech CNC router experiences and potential a 4th axis ?
    By Kent_Norway in forum Commercial CNC Wood Routers
    Last Post: 12-14-2007, 01:09 AM
