603,942 active members*
3,433 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Hand Tools to CAD
Results 1 to 7 of 7
    Aug 2005
    50
    Hand Tools to CAD
    Good Morning,
    I'm after a little help. I want to create a shadow board for my hand tools but would like to get them into CAD first to get the best positions of the tools on the board. I also want to get the images set to cut them out in a colour etc.
    The nuts of it all is how do I get my hand tools without measuring every radius and size into AutoCAD?
    I thought maybe drawing round them then using a digitizer, or one of these digipens?
    Any ideas would be great.
    Ant
    Apr 2011
    Put them on a scanner if you can and then trace the scanned JPEG?
    Aug 2005
    50
    Some of them are too big for the scanner. How do I trace the scanned image?
    Ant
    Apr 2011
    Quote Originally Posted by antsals View Post
    Ant
    Use the Cad program or maybe MS Draw? You could possibly take multiple scans and join them up to make a bigger image?
    Aug 2010
    90
    shadow board
    hi'ya antsals, photograph your tools and workstation with a scale in each picture and then vectorize the out-lines and space to scale, you can then move/place til you are satisfied, then print full scale - :rainfro::rainfro::rainfro: kelef
    Dec 2008
    4545
    You could also see how many already exist as models:
    3d content central
    Sometimes going to a tool manufacturers website, you can get the models from them too...
    May 2008
    99
    FWIW... we snap a few digi-pics, and then just insert them into CAD as an image, and start drawing over the top of it. We use Inventor, but we used to do this in AutoCAD as well.
    You're drawing lines and arcs freehand, using the image as a guide. Depending on the resolution of the picture, and your patience, you might be off by a pixel or two, but this is normally acceptable tolerance
    One thought is to trace as precisely as you can, and then offset the resultant p-line to get the clearance you want.
  1. Attaching hand tools to router table
    By Neil Davie in forum DIY CNC Router Table Machines
    Last Post: 01-08-2011, 06:40 PM
  2. hand scraping tools
    By FSG in forum Community Club House
    Last Post: 09-30-2010, 08:04 PM
  3. need basic hand tools and box
    By alw01 in forum Want To Buy...Need help!
    Last Post: 04-22-2010, 11:37 PM
  4. Best Way To Cut Rubber With Hand Power Tools
    By lostbaka in forum Material Machining Solutions
    Last Post: 03-09-2008, 05:27 AM
  5. Bending/Cutting With Hand Tools
    By cibressus in forum Bending, Forging, Extrusion...
    Last Post: 08-13-2006, 06:33 PM
