588,357 active members*
7,523 visitors online*
    Feb 2011
    Something HAS to be wrong with my steps per inch....
    Hi folks.
    Im a total newbie, I'll admit.
    Im running a cncrouterparts.com design 80/20 build.
    I'm using a Gecko G540, Nema 23 steppers, 5 start 10 tpi leadscews, and of course mach3.
    I have seen others using steps per inch at "4000"
    200 step motors x 10 microstep drives, x 2 turns per inch on the screws.
    But, my steps per is only accurate around "160". Thats right, one-hundred-sixty.
    I cant figure out what I'm doing wrong. Any ideas?
    You probably have your default units set to mm's. Change to inches and retune the motors.
    Feb 2011
    I did check that, I thought it was correct, but now I'm guessing not.
    160 x 25.4 (mm in an inch) = 4064
    Will recheck and report back.
    Feb 2011
    Yep. Sure was in "mm"
    Here's where it gets really interesting.
    I reset my steps per inch with mach loaded up with no G code.
    I had to set it to about 100,000 steps per inch to be in the ballpark of 1 inch. I knew this wasnt right, but it worked....sort of....The DRO on mach read 1 inch of movement for 1 inch of travel.
    Then I loaded my G code, and the steps per inch was no longer accurate. It changed, with my G code loaded, to where I wanted to be, 4000 steps per inch.
    Great, I suppose, but why did my "steps per" change when the G code loaded?
    You have a G20 or G21 in your g-code, which is changing the units.
    You're steps per unit isn't changing.
    Set the default units to inches, set the proper steps per inch, and make sure youre g-code doesn't have a G21 in it, and it should work fine.
  1. Calculating steps per inch!
    By Pplug in forum DIY CNC Router Table Machines
    Last Post: 12-10-2010, 12:03 AM
  2. Steps per Inch Question
    By jtluttrell in forum Linear and Rotary Motion
    Last Post: 01-13-2010, 02:07 AM
  3. Steps per Inch / mm
    By themonster in forum Linear and Rotary Motion
    Last Post: 08-25-2008, 02:08 PM
  4. steps per inch
    By Chris Tucker in forum Linear and Rotary Motion
    Last Post: 08-14-2008, 01:50 PM
  5. Steps per inch formula, What I am doing wrong?
    By Noah in forum Gecko Drives
    Last Post: 05-28-2004, 12:56 AM
