hi all,
ive been looking at some chinese machine recently. this would be our first CNC router purchase so i'm hoping for some advice.
this machine is available with a triple head, vacuum hold down, dust extractor, 2.2 KW spindles and delivery to UK for $8500
here is the spec:
JCUT MODEL
JCUT-1325A CNC Router
Working Area (X*Y*Z)
1250X2460X100mm(49.2X96.8X3.9 inch)
Processing accuracy
0.01mm
Repositioning accuracy
0.05mm
Spindle
1.5KW variable speed , water-cooled
Spindle rotating speed
0-24000rpm/min
Max Moving Speed
6000mm/min
Working speed
0-5000mm/min
Driving mode
Ball screw
Voltage
AC220V/50Hz and AC380v
Max. Power consumption
1.9KW
Feeding Height
150mm
Drive motor
Stepper
Command
G.code , mmg , plt , uoo,HPGL
Compatible Software
Type3, Artcut, ArtCAM, masterCAM software
Certificate
CE,FDA
Pack dimensions
1700mm X 2900mm X 1650mm wooden trunk
Net weight
480KG
does that sound ok? seems pretty good to me. has anyone here had any experiance with this company?
all feedback welcome. thanks
zac
