587,263 active members*
3,411 visitors online*
IndustryArena Forum > CAM Software > OneCNC > Computer Spec?
    Dec 2004
    150
    Computer Spec?
    Hello, What sort of computer spec are you guys running XR4 Expert on? Do you have decent process times on tool paths.
    Thanks,
    Keith.
    Mar 2003
    4826
    A meaningful comparison of computer hardware could only be done by common testing of an existing file with sufficient complexity to represent a 'calculation load'.
    Long calculation times can occur any time toolpath parameters are set to very tight tolerances, or boundary constraints are too close to permit easy tool movement (when considering the finish allowance).
    But any 4 core cpu should give you lots of oomph, with 6 gigs of ram....pretty much a standard 'higher end' PC nowadays.
    First you get good, then you get fast. Then grouchiness sets in.
  1. help needed, on computer spec
    By paulkane1 in forum Computers / Desktops / Networking
    Last Post: 01-02-2011, 01:08 AM
  2. advise on this computer spec
    By paulkane1 in forum Controller & Computer Solutions
    Last Post: 01-01-2011, 11:10 PM
  3. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  4. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
  5. Need to know the spec. of this stepper
    By CrazyRonny in forum CNC Machine Related Electronics
    Last Post: 05-27-2004, 04:28 AM
