603,855 active members*
3,877 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PCNC1100 and Calypso MachStdMill
    Dec 2010
    I'd like to use MachStdMill with a Tormach PCNC1100. MachStdMill REQUIRES Mach3 version 3.43.22 or newer but the latest Tormach software is based on Mach3 version 3.42.29. Tormach says later versions "might" work but don't know. They also said they think some later versions use a different config file format. I know there are folks on this forum that have done this. Please share your experiences!
    Rich
    Nov 2010
    360
    Quote Originally Posted by rich_s View Post
    Rich
    I have used 3.43.22 and currently use 3.43.35 with no issues. The configuration file worked just fine. I heard there are issues with 3.43.45 so I would avoid that.
    Jul 2007
    131
    Has worked great for me
    I've been using the latest release of Mach3 3.043.022 (gota fix my signature) with the Mill Mach Steel Blue screen for about a year now. This latest version uses mach pulse driver 5.50.
    On my PC with the Tormach ver. of Mach, I would typically see 8-10uS of Max variance during DriverTest. The latest driver version is solidly at 5uS...your milage my vary The Mach3 change log mentions many fixes since the Tormach release.
    With this release and some parameter changes, I have run my 1st generation machine at a 105 IPM, all axis test for 3 days no stop. I checked the Work Offset position several times and it never missed a step. I backed it off since then to 85 IPM and has been trouble free.
    Tormach PCNC1100, Mach 3 R3.043.037, MastercamX5 level 3.
    Dec 2010
    Thanks dbrija and btu44! Very helpful.
    So if I wanted to run 3.43.22 with my Tormach, I assume I would install Mach3 3.43.22 and then use the Tormach XML configuration file. Is that right? Would I have to merge the standard Mach3 3.43.22 configuration file with the Tormach file? Same question for MachStdMill. I haven't looked yet but I'm assuming there are parameters unique to each file that would need to be in the final configuration file.
    Any other steps in getting 3.43.22 up and running with the Tormach?
    Thanks again!
    Rich
    Jul 2007
    131
    Rich,
    Tormach asked me to not post details on making these sorts of changes.
    Feel free to PM me...Tormach's cool with that.
    Barry
  1. CMM Operator-Calypso & PCDMIS - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 11:02 PM
  2. Announcement: MachStdMill (MSM) Released
    By mvcalypso in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2011, 07:51 PM
  3. Lot of problems after new install and MachStdMill
    By jeffrey001 in forum Mach Software (ArtSoft software)
    Last Post: 01-21-2011, 11:13 AM
  4. My Tormach PCNC1100 arrived today
    By pstockley in forum Benchtop Machines
    Last Post: 04-06-2006, 09:31 PM
  5. Tormach PCNC1100 vs CNC Mill Drill
    By sidoiler in forum Benchtop Machines
    Last Post: 01-05-2006, 09:41 AM
